Question about Haier HLP140E Electric Portable Dryer
NEED TO PUT THE DRUM BELT BACK ON ASAP
I NEED HELP TO PUT THE DRUM BELT BACK ON MY HAIER DRYER. THE REPAIR MAN I HAD COME IN GOT SO ANGRY AFTER A CALL FROM HIS EX, HE TOOK THE CHECK FOR WHAT WORK HE DID AND SAID 'I QUIT, NO MORE WORK MEANS NO MORE MONEY FOR THE EX'. LEAVING ME STRANDED TO PUT A BELT BACK ON, I KNOW THIS MUCH.....THE BLACK THINK BELT GOES AROUND THE DRUM...I CAN TRACE THE MARKS WHERE IT HAS BEEN...BUT I DO NOT KNOW HOW WHERE THE BELT GOES AFTER THAT.....THERE IS A WHILE PULLY AND A BLACK PULLY.I CAN SEE THAT ORANGE BELT I REPLACED IS ON THE BLACK PULLY....WHEN I PUT THE DRUM BELT OVER THE DRUM THEN AROUND THE WHITE PULLY THERE IS STILL SO MUCH SLACK....IS THERE SOMEWHERE ELSE THIS GOES AROUND ALSO LIKE ANOTHER PULLY? THANKS....I NEED THE HELP ASAP....PLEASE!!!!
    Problem Solver:
  • 13 Answers
There should be two pulleys and the drum. **I am not a certified appliance repairman. Please make sure you have disconnected the power source before servicing the unit** You should see a pulley that is attached to the electric motor that actually makes the belt spin and the drum turn. The motor will have electrical wiring attached that you shouldn't touch. The other pulley is called a tensioner pulley and should be spring loaded to add enough tension to the belt once it is routed properly. To work correctly, the belt has to go around the drum, around the motor's pulley, and then across or around the tensioner pulley so that there is no slack in the belt and enough tension to turn the drum. Does that make sense? It is hard to say the exact routing of the belt without seeing a picture but that is how it has worked on all the dryers I've ever repaired. Hope this helps!
Posted on Apr 17, 2014
Testimonial: "thank you to all that helped me....I am now able to dry my clothes and have a great working dryer again!! Blessings to all...."
  • 3 Answers
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
HOW DO I PUT DRUM BELT ON A PORTABLE HAIER DRYER I HAVE ORDERED THE BELT IT CALLS FOR FROM HAIER COMPANY TWICE AND IT IS STILL TOO LONG MAYBE I AM PUTTING IT ON WRONG help please
Your idler pulley will take up the slack in it. It won't be real tight any way once on. If there is still a lot of slack when ou turn it on and the drum doesn't turn, then take it back. Take the old belt with you so that it can be matched uproperly.
Jan 25, 2015 | Haier HLP140E 115 volt portable dryer...
REPLACING THE DRUM BELT
Belt should go around entire drum then around motor pulley (which is metal) and tensioner/safety pulley (which is the white pulley)
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
PUTTING FAN BELT ON THE HLP140E DRYER
Remove the lint trap. And bolt behind it. You can then move drum or lift out to get ar screws on crossbar
Apr 15, 2014 | Haier HLP140E Electric Portable Dryer
NEED TO REPLACE THE FAN BELT ON HAIER DRYER MODELHLP140E
Remove the lint trap. There is a bolt in the center. Remove bolt. Remove screws from crossbar and you can then replace the belt. I removed sensor and lifted drum out makes it easier. Pay attention to how black belt is thread if removed
Apr 04, 2014 | Haier HLP140E Electric Portable Dryer
My tumble dryer has stopped spinning!!
Hello jemmie. Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. If you want to do this repair yourself you can order the part at searspartsdirect.com
Joe
Thanks for choosing Fixya!
Nov 30, 2010 | Haier GDZ5-1 Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
Drum Stuck
Frigidaire GLEQ2152ES Electric Dryer. I have checked the dryer pretty thoroughly and can't find anything jamming. I believe it is a bearing. Something on page two of the manual. If I can, I will repair it myself. That area has been diffucult to access.
Thank you
Jan 25, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Haier HLP140E Electric Portable Dryer Logo
200 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
