Question about Remote Start System
Viper 5101 no longer starts
Jeep liberty everything worked then one day the remote start stopped starting the car. lock/unlock works, remote start turns accessories on (power) but doesnt crank. key in the ignition in any position still doesnt start
    Problem Solver:
  • 8 Answers
Are your brake lights functioning properly? remote starts sometimes use this as a fail safe, or a bent hood pin switch? Also It may need the tach reprogrammed if used. there may be a seperate fuse for the starter.
here is the link to the installation manual: http://www.directeddealers.com/manuals/ig/viper/n4102v_2008_09_web.pdf
and the page regarding this issue: • The remote start will activate, but the starter never engages.
1. Check for voltage on the purple starter wire two seconds after the remote
start becomes active. If there is voltage present, skip to Step 4. If there is
not voltage present, advance to Step 2.
2. Check the 30A fuses.
3. If the gray/black wait-to-start wire is detecting ground upon activation, the
starter will not crank.
4. Make sure the purple starter wire is connected on the starter side of the
optional starter kill/anti-grind relay.
5. Does the vehicle have an immobilizer? Some immobilizer systems will not
allow the vehicle to crank if active.
6. Check connections. The heavy gauge remote start input wires on the
heavy gauge 10-pin connector should have a solid connection. "T-taps"
or "scotch locks" are not recommended for any high current heavy gauge
wiring.
good luck.
Posted on Apr 17, 2014
Boole5555
  • 160 Answers
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
Posted on Jan 13, 2010
  • 151 Answers
SOURCE: my viper remote starter cranks engine but car
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
  • 4 Answers
SOURCE: Viper
did it ever work before?
A couple things here. It is best to have a "tach wire" and the system needs to be programmed to learn the tach signal in order to know if the car is running or high reving or dead. If it gets no signal of the sort the next option is voltage monitor, it monitors the voltage for an increase to show that the alternator is running. Either way that signal is not gettting to the viper brain or it has not learned that signal. You need an install manual, did you install the alarm?
Posted on Mar 25, 2010
logosc75
  • 625 Answers
SOURCE: I have a Viper 5301.
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Posted on Apr 19, 2011
logosc75
  • 625 Answers
SOURCE: My viper remote worked perfect,
The issue is not with the remote as you have stated the vehicle attempts to start. The issue may be with an immobilizer bypass module but, I can't say for sure because you mention the year/make/model of the vehicle. Usually the vehicle will give you visual reason for the failed attempt( the lights will flash a set number of times). But, in any event, the issue is not with the remote and more information is required to assist you.
Posted on Apr 27, 2011
How do I reprogram a viper 5101 remote starer
on remote press the middle button for 15 sec. after three flashes on remote, put key in ignition and turn ignition on but dont start it. press button on antenna, release and then hold until horn honks or led flashes on antenna. lastly press lock within 5 sec
Jul 30, 2014 | 5101 LE 1 Way Car Remote Starter System
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
May 11, 2017 | 5101 LE 1 Way Car Remote Starter System
I got the Viper 5101 remote start installed in my 2007 Hyundai Sante Fe at best buy. The remote works for auto start, but will only lock and unlock the doors sometimes. It seems like if I unlock or lock...
I would take it back and tell them they need to fix it. it sounds like a wire for the lock/unlock may of fallen off or there is a problem with the remote stare module. wires tend to fall off if all the used were crimp connectors and didn't solder the wires together.
Jun 01, 2017 | Hyundai Santa Fe Cars & Trucks
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
2001 jeep grand cherokee /viper 5101 rs with keyless entry all wires are hooked up properly as far as im concerned but remote start will not activate i have a 7 flash diagnostic code
I'd say the easiest thing would be to stop being a lazy tw@ and get into the vehicle with a key as normal. Come on, lose some wait...
Mar 11, 2011 | Remote Start System
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
Stop working
Well if your alarm doesn't work and your car doesn't start is because it has have installed what is call killswitch.You have to disconnect your alarm and attach togeter your wire that it runs to your killswitch.
Jan 04, 2010 | Remote Start System
Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Jul 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote Start System  Logo
201 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
