Question about HP Photosmart M525 Digital Camera
My camera lense will not open
I turn on my camera and it says lens error
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 13, 2012
4 Suggested Answers
  • 102366 Answers
SOURCE: hp digital camera m730-033 displays lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
  • 102366 Answers
SOURCE: Lens Error
caroldon
  • 17130 Answers
SOURCE: i dropped my camera and
There can be a mechanical break or a lens mounting break due to the fall and so the camera must be opened out to reset the lens hood.
You will need some experience to remove carefully and checck the drive for the dislocation of the motor control.
It can be a visual indicatiion to the fault if looked in and can be removed ,reset or the brokedn part glued into the mount.
Posted on Oct 01, 2010
When you turn the camera on the lense opens and the camera shuts off with the lense still open. I turn on again and the lense closes and then shuts off.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 30, 2011 | Pentax Optio 60 Digital Camera
When I turn on the camera, Lens error shows up on
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 27, 2009 | Nikon Coolpix S210 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
My EX-S5 says lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
Lens do not open
try smacking the sides of camera.also try to make the lens up down with you hand couple of times.then check out.
Mar 23, 2009 | Cameras
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
HP Photosmart M525 Digital Camera Logo
27 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
