Question about Electrolux Ovens
Electrolux wall oven microwave combo keeps blow microwave fuse
  • Electrolux
    Electrolux Apr 22, 2014
    Good Afternoon Cotto1,
    I see that your Electrolux wall oven combo keeps blowing the microwave fuse. I really want to be able to assist you with this; however, I will need the model number of your appliance to better assist you. I will be looking forward to hearing from you.
    WP
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
reg501
  • 413 Answers
SOURCE: microwave oven
The high voltage capacitor is probably shorted, (large, silver, oval shaped part). typically .98mfd to 1.02mfd
Posted on Jun 03, 2008
heatman101
  • 43501 Answers
SOURCE: Electrolux wall oven not heating after self cleani...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on May 19, 2010
SOURCE: Electrolux EOG600WN gas oven trips out circuit
You have a shortage in your wiring system and you'd need to call for service.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Posted on Jan 25, 2011
SOURCE: KitchenAid Wall and Microwave Oven Combo - KEMS308SSS
After using the microwave for a month, the amount of time to heat has increased significantly. For example, 1 cup water now takes 3 minutes to reach 158 deg and 4 min-40 sec to reach boiling (212 deg)
This model KEMS308SSS02 was installed in July 2008 in a new condo. It was never used until Feb. 2011 when we moved in as the first owners.
Any advice would be appreciated.
Posted on Mar 18, 2011
Lower oven will not heat, circuit fuse is OK
You will have to remove the unit, to access the back and pull the covers, most likely you coil is burned out. Or a safety fuse to the coil is tripped last but not least, your control card is burned out. Might want to give make and model
Nov 11, 2015 | GE Jkp90Dpww 27" Built-In Combo Microwave...
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Sep 10, 2012 | Electrolux ICON Designer E30SO75ESS Oven
Wall microwave worth fixing?
There's micro switches and fuses worth fixing on microwaves... if its doing nothing its most likely the fuse on control board. maybe even the breaker.
Sep 01, 2012 | Ovens
My electrolux EOD5330 fan oven tripped a fuse. ow it won't heat. The fan still works
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
Feb 10, 2011 | Electrolux EOD5330 Ultrafan Electric...
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Jenn air combo wall oven/microwave
Jan 01, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
