Question about Reddy R60A Utility Heater
Will not start, no sound when i turn it on. - Reddy R60A Utility Heater
    President:
  • 2,923 Answers
Here are the things that you need to check, you may need to refer to the user manual of the Reddy heater:
1. Fuse - try to replace the fuse
2. Capacitor - test the capacitor if it's good.
3. Heat Pump coils -
Heat pump coils are where most of the problems occur when dealing with a heat pump
You’ll need to check and turn on the main propane tank all theway. The last step is to press and hold down the safety valve buttonand press the ignitor button several times or until you hear theburner ignite.
Once the burner is lit continue to hold the safety valve button for another 20 seconds or so, then let go.
If you need to change a part, you may check this link:
http://www.reddyparts.com/
Hope this helps and have a great day!
Posted on Jun 18, 2009
Wont turn over
When you say "makes the sound like it wants too", is that the starter motor making the sound, or just a click?
Your heading said "Won't turn over", which means the starter doesn't turn at all.
If it's makes just a single click each time the starter button is pushed, that usually is the starter relay, a $15-$20 part.
Mar 18, 2014 | Harley Davidson FXSTDI Softail Deuce...
Ford Ka starter motor won't start but makes whirring sound. It usually takes 3 turns of the iginition to start
Sounds like the solenoid is bad on the starter..Starter probably needs replacing.
Feb 23, 2013 | Cars & Trucks
Start, drive, stop, need boost to start again; then after a day of not driving it will start without boost on the second day. What's going on?
check your battery. i had the same problem two months ago. i thought it was the alternator or starter , but the shop said i my battery wouldn't keep a charge.
Dec 27, 2011 | 1993 Cadillac Fleetwood
My disher washer is making a high pitched sound when I turn it on.
is this a new unit or old one? the high pitched sound is the pump some models make this sound every time they start up. it will make the sound when you start it up but then goes away. try this before you start it run the hot water in the sink let it get hot turn off the faucet then turn on the dishwasher.
Feb 24, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a 1993 dodge caravan and it wont start. the buzz sound that i use to hear when the car starts i dont hear any more. the sound came from the back of the car. when i turn the key it sound as if it...
Sound like your fuel pump quit working. That is what makes the buzzing sound from the back. Sometime if you have someone that can help you you can bang on the gas tank while turning it over to get it started to get it home.
Nov 08, 2010 | 1993 Dodge Caravan
Will not start. engine turns over very fast but
Hi does it sound like it is turning over much easier than normal? much faster as you say.
If so, it sounds like the timing chain/belt has broken
or the starter motor celinoid or the starter not catching.
Does the engine sound exactly the same tone wise or is it much higher pitch when trying to start?
Regards
Dan
Feb 01, 2010 | 1996 Mercury Grand Marquis
DRYER SOUND LIKE IT WANT TO START BUT WILL NOT START.
With no load and unplugged - does the drum turn freely by hand and not make any grinding sound? Should turn smooth and no noise.
Mar 27, 2009 | Dryers
Reddy R60A Utility Heater Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
