Question about Fender G-DEC Junior Modeling Guitar Amplifier
Power light blinking instrument
So i was playing and it just shut off now every time i cut it on the power light blinks
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
How to set onboard fx processor
Which clip light on what and what mics are you using?
The small room settings are from 10 so just turn the know to the setting you require and press it, this should set it.
The stadard way of setting up mics is to set the channel gain so the channel clip light just blinks occasionally when you are making the maximum sound you can into the mic.
For effects repeat this process using the aux send FX for each channel you want fx on (turn the rest to 0) and doing a balancing act between these and the aux send fx master so you can only just get the FX clip light blinking occasionally.
Next set your gain/attenuators on the amp(s) so its clip warning can just trigger when you are giving it 0db when you are playing the loudest you ever will.
A mic fading away could be the battery dying (in which case try using phantom power) or if they're radio replace the batteries before each service. If they're wired dynamic mics then it is possible there's some protection circuit somewhere that's reacting to the constant clipping and backing off the amp.
Mar 22, 2014 | Behringer XENYX 2442FX Mixer
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
Oct 07, 2013 | Bugera 333XL Infinium 120 w 3 Channel...
The display screen for my DGX 500 is blinking on and off and is unresponsive.
Do you mean,"The HOUSE power went out" or, "The keyboard power went out"?
Mar 20, 2012 | Yamaha Music
I bought my g-dec jr form ebay last summer and really like this little amp but this past winter I went to use it, it worked for 3 to 5 min and shut down, but the power light just blinked moderately. I...
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Jul 16, 2011 | Fender G-DEC Junior Modeling Guitar...
When i play a bit loud (not too much though just when the light blinks red on the hard play) the sirquit closes the amp for two seconds.can you healp me on this ?thank you very much
does your bass have active pick ups?
do the ratings on your amp match the ratings on your speaker?
are you using a pedal?
does your pedal have an output adjustment?
have the ground on your bass checked.
make sure you're using the right kind of cable.
and be sure that the outlet you're using is grounded.
Feb 08, 2011 | Ibanez P500H Promethean Bass Amplifier...
Guitar cutting out and distorting
I wish I had more info: Now if you turn off the unit for a while and then turn it back on lets say a few hours and it works good for a while like an hour or so. If this is the prognosis thus far I would say it has a over heating problem. Place the unit on something that will rase it up so air can flow all around it. Try a small fan blowing on the unit this will keep it cooler. If this is the case you don't want to over heat it many times ,if you get my meaning. There all so may be a reason internally that would cause the unit to over heat , if this is really whats going on . It wont cost you anything to give this a shot.I hope it works. Good luck DFD please rate me TK U
Apr 11, 2009 | DIGITECH VOCALIST LIVE 2
Fender G-DEC Junior Modeling Guitar Amplifier Logo
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
