Question about Food Mixers
Pyrex digital instant read meat thermometer battery size
2 Suggested Answers
  • 8 Answers
SOURCE: I have a Sunbeam digital
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Posted on Oct 09, 2010
Can it chop meat
Food mixers don't usually chop meat, however if it has a 'cutting' blade it may be able to. This will probably be stainless steel and very sharp.
Mar 16, 2015 | Food Mixers
Need instrucion manual for moulinex electric meat grinder & salad maker
You don't mention what model number, but you might try this page. It has several meat grinder instructions booklets you can download.
http://www.moulinex.com/Pages/default.aspx
Jul 22, 2014 | Food Mixers
Meat mashes when grinding
The knife and plate are either worn or are not tight before meat comes in contact. Always keep a knife and plate as a matched pair as they will wear into each other.
Mar 02, 2014 | Food Mixers
Hobart meat grinder,model 4322 asking what type of oil in gearbox to use?
You can buy food grade grease from kitchenaid or on amazon. I did use the grease from my work. Any grease would do the job just make sure you read the specifications to find the grease that can stand high heat so it doesn't melt while the machine is running.
Dec 13, 2011 | Food Mixers
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Sharp Carousel II convection microwave oven stopped working
the circuitry has gone bad, the piece of meat may have caused it to work a little harder than normal and was probably close to quitting and heating the meat just made it finally quit
Jan 15, 2010 | Food Mixers
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid sausage maker does not stuff the sausage casings
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
Jun 01, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
47 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
