Question about Kenmore Sears Electric Range Stove Oven 288970 Wb25m3 Indicator Light
Oven door Took apart to clean glass and now can't put back together! Did not take door off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Nectar time take a photo first, they generally only go back one way.
removing the door may make it easier open the door see the hinges on the bottom lift up the little cam on each hinge then just lift the door up & it should come out.
Posted on May 08, 2014
Re assembling the door....
As a general rule of thumb, oven door glass assemblies are not intended to be removed for "cleaning" or some such procedure. Go to www.repairclinic.com and enter RBS275PDB8. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool oven disassembly video which may help.
Aug 15, 2016 | Whirlpool RBS275PD Electric Single Oven
How can i clean the glass between my oven door,i noticed streaks and it makes the oven look dirty
Whirlpool door are a bit difficult to remove from the stove. the owners manual may tell you what you need to do to remove it. Once you have it off then the door can be taken apart by removing tye screws that hold it together. This should be done on a flat surface and taking a lot of care. Remember how it comes apart and reverse the procedure when putting it back together. If you break a glass they are expensive to replace if available.
May 30, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Really how do you get to the inner glass, it has a disgusting line of **** inside i would like to clean thanks
IF YOU OPEN THE OVEN DOOR THERE SHOULD BE SOME SCREWS YOU CAN REMOVE LOOK AROUND THE DOOR EDGES FOR SCREWS ALSO REMOVE THESE AND YOU SHOULD BE ABLE TO PULL THE INNER DOOR OFF LOOK MAT THE GLASS CAREFULLY IF THE GLASS IS SEALED TOGETHER WITH ADHEISIVE DO NOT PULL GLASS APART, IF IT HAS A GASKET FINE SEPPERATE THE GLASSES AND CLEAN AND PUT BACK TOGETHER
Feb 05, 2011 | Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
Apr 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven windows
I have the same problem. Two years ago the service representative came to my house to replace the door seal in my upper oven. He had to take the door apart to remove and replace the part. I used that opportunity to clean the interior glass partitions. I watch how he took it apart and put it back together again. I would not recommend trying it yourself. Also, local service reps. would clean it for you for a nominal fee. The problem is taking the bigger heavier door in which I have to do with mine.
Jun 18, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Need help putting GE oven door back together again
they're called towers. They go on the 2 long screws once you've put the screws through - so they go between the two panels. They are used to space the 2 panels so that they line up flush when they are back together.
Jan 09, 2008 | Kitchen Ranges
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Kenmore Sears Electric Range Stove Oven 288970 Wb25m3 Indicator Light Logo
74 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
