Question about Sony Cameras
Disable esc lens does not come out
How to disable the video on a A780L motherboard
North Bridge Co nfig uration
BIOS SETUP UTILITY
Chipset
vxx.xx (C)Copyright 1985-200x, American Megatrends, Inc.
Select Screen
Select Item
Go to Sub Screen
General Help
Save and Exit
Exit
Enter
F1
F10
ESC
NB Chipset Configuration
NB CIMx Version : 4.4.0
> PCI Express Configuration
Primary Video Controller [PCI-GFX0-GPP-IGFX]
NB Power Management Features [Auto]
> Internal Graphics
Internal Graphics Conf
Internal Graphics Configuration
BIOS SETUP UTILITY
Chipset
Select Screen
Select Item
Change Option
General Help
Save and Exit
Exit
F1
F10
ESC
Internal Graphics
UMA Frame Buffer Size [Auto]
FB Location [Above 4G]
AMD 780L HD Audio [Enable]
Internal Graphics Mode [UMA]
Surround View [Disabled]
Options
Disable
UMA
T his item allows you to select the memory mode used for internal graphi cs device.
Options: UMA (Default) / Disable
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiwq5ik2rXQAhWKP48KHU--AYMQFggcMAA&url=http%3A%2F%2Fmediapool.getthespec.com%2Fmedia.pdf%3Fm%3DQNJ2kCQfmVPhBYToYbwEQw%253D%253D%26v%3DPD&usg=AFQjCNGEH6Nge9c54_Uk8domc9vJiL0eTw
Nov 19, 2016 | Computers & Internet
ESC OFF is switch on
Yes, and press the switch and ESC will turn on. The switch enables or disables the ESC. When you turn off the vehicle and turn it back on, the ESC will automatically turn on regardless of whether it was on or off when you last turned the car off. If you want to keep the ESC disabled, you will need to push the button each time you start the car. The ESC is not the ESCape hatch. It is the Electronic Stabilization Control. This is a computer operated system of interworking devices that help keep the car stabilized and driving correctly. It includes the antilock braking system, the antiskid system and the traction control system (if equiped).
Mar 08, 2014 | 2006 Hyundai Sonata
How to enable disabled boot menu items
you must restart the computer Hold the keys CTRL +f2 or esc and enter the BIOS setup, go to the tab, appearing the selection of BOOT and enable or disable, that option that you wanted.
God bless you
Jul 27, 2013 | Computers & Internet
I need to disable my Lenovo G550 touchpad, is there a solution?
To be able to Disable the touchpad you need to press FN + F6 to disable it you can enable it by pressing the same keys. Some Helpful Keys that you need to know about Lenovo.
FN + F5 - Enable/Disable Wireless
FN + Esc - Enable/ Disable Webcam
Don't Forget to say Thanks. Thanks for using Fixya.
Feb 05, 2011 | Lenovo G550 Notebook
Please tell me what this warning light means on my dash: ESC off.
This is the light that tells you that the Electronic Stability Control or ESC has been disabled. There should be a button in you vehicle that has a car and or some tire markings on it or it may just read ESC, and pressing it will turn it back on.
Jan 21, 2011 | Hyundai Sonata Cars & Trucks
ESC light on/Now it says ESC OFF
Electronic Stability Control (or ESC) is a new crash avoidance system found on many vehicles. Unlike air bags, which only help you during a collision, ESC will help you to avoid loss of control that could lead to a collision.
ESC is designed to help you stay in control of your vehicle during an emergency manoeuvre, such as when you need to swerve or brake suddenly to avoid an obstacle.
ESC monitors your steering versus the direction of the vehicle. When they do not match, ESC will automatically actuate the brakes at one or more wheels for short periods of time, reduce engine power, or both. If at all possible, ESC will help you maintain control of your vehicle.
ESC is automatically "ON" whenever you start your vehicle. Some vehicles have an ESC Off switch; this switch is needed to disable ESC during certain situations such as when you are stuck in snow. If your vehicle has an ESC Off switch, refer to the vehicle owner's manual for more information. Unless you manually shut ESC Off, it will remain active until you turn the engine off.
Please rate this fixya
Jan 27, 2009 | 2007 Hyundai Sonata Limited Sedan
Esc light comes on and car wont go into park or any other gear other then D and N.
Jan 17, 2009 | 2007 Hyundai Sonata Limited Sedan
Can I disable Sleep Button
If you are using Vista ... control panel.... system and maintenance.... Power Options. On the left there is an option for "Choose what the power buttons do" You can disable the sleep button there. C'mon Compaq... get a brain!! Who's dumb idea was it to put the sleep button there?
Aug 28, 2008 | Compaq Keyboard
Disabling touch pad
The touchpad should be able to be disabled through the BIOS.
Restart the computer, then push F10 to access the BIOS - if F10 doesn't work, try the other function keys and possibly the ESC key. You should find the option to disable the touch pad within the BIOS settings.
May 09, 2008 | Compaq Evo N610C Notebook
Lenovo Y410 Integrated webcam not working
If the Y410 is like my Y510 then it is possibly one of two things.
1. If the computer goes into "sleep" mode, the camera may not come back online when it wakes up. A restart will obviously fix this.
2. Does your keyboard have a Fn key assigned to the ESC key that will toggle the camera ON/OFF? If so, give that a try.
Big John
Feb 22, 2008 | A4tech Xmaster PK-835 Webcam
Cameras Logo
14 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
