Question about Westinghouse Televison & Video
Westinghouse cw50t9xw turned off tv last night and it wont come on today no orange status light
  • 317 Answers
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Posted on Jun 03, 2008
  • 5 Answers
SOURCE: Protron pltv3250 32 in. lcd, no power, no lights
You will have to have the set checked by someone to confirm this,
but most likely there is a problem with the TVs internal power supply.
Posted on Jan 25, 2009
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
SOURCE: I have a Westinghouse TV , when turned on the
I just fixed the same model and with your symptom. What it appears to be is the main module is locking up just after the Logo goes away. All you can do is unplug and try again and all you will get is the logo for 5 seconds and then black screen, no sound and led stays lit. Cannot turn off or on. The power supply is actually working fine, it's the main module that has died. This module is no longer available, the part number was W470PROLX68. What i did to restore operation on this unit was to insert 3 volts into the plug going to the master inverter board and then plugged the tv AC cord in. The set showed the logo and then it started working. I removed the 3 volts and it has worked every time since then.
Here is what you should try to do: First take two AA batteries and solder them in series and attach two short wires so you can use it as a power source. Now you have a 3 volts power supply. Next Remove the stand first before removing the back cover. Looking at the back of the unit you will see the power supply and the main circuit boards in the middle (under metal shields) and two boards on each side. These are partially covered with a metal shield, the one on the left side is the master inverter, the one on the right is the slave inv. They both have a plug and wires going to them from the power supply, but the one to the master will have two extra wires. I believe the colors are purple and blue, and they are separated with an empty hole (unused part of the plug). The wire on the end is where you will hook up the positive lead of your battery pack. The negative lead simply goes to the metal shield. With these hooked up plug the tv into the ac and give it a couple seconds and hopfully you will see the tv come on. If it does then disconnect the battery pack and try it without it. good luck.
Posted on Nov 17, 2009
  • 29 Answers
SOURCE: westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Posted on Feb 18, 2010
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
Mar 18, 2011 | NEC VT595 LCD Projector
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
Tv won't turn on
it was damaged during transit to you
May 29, 2009 | Westinghouse TX-52F480S 52 in. LCD TV
Loewe Vitros 6370- won't turn on!
its a power supply problem.
Jan 13, 2009 | Televison & Video
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
