Question about Magic Chef Refrigerators
Fresh food side isnt staying cold. Freezer is staying cold though but the ice is sweaty a little. Model RC244AD
I have cleaned the back and most of the dust from fan/condenser area.
    Sergeant:
  • 264 Answers
Hi I'm Peter, The fresh food side will have a different thermostat it is likely that the thermostat or the thermocoupling has gone bad. The thermocoupling will be a tube shaped device mounted on the coils possibly underneath since it's for the cool side fridge see if it is operating by blowing on it with a hair dryer that may activate it. I would check the thermostat first though. . OH WOW CAN'T BELIEVE I DIDN'T MENTION THIS FIRST Make sure and check the door gasket that it is not leaking a temp gun could be used for that as it would register cooler where there was a leak. Is the compressor running all the time or is it cycling? It seems it would be ok if the freezer is operating properly so it all leads back to the thermostat. Most appliance parts stores will have these in stock just take the make, model, and serial number and they may have some more suggestions as they would most lkely know what parts on a particular make goes out the most.
Posted on Apr 17, 2014
GSL22JFRE BS Freezer OK but not Fridge ??
Clean the condenser grille, rear and under unit
Apr 24, 2012 | GE GSL22JFR Side by Side Refrigerator
Refrig is not cooling. freezer cold but not freezing. Already cleaned condensor
several potential problems
1) evap fan motor isnt running to circulate air into fresh food side
2) it isnt defrosting (do ya see what looks like snow on back of freezer)
3)depending on brand or model their is a damper which isnt opening to allow air flow into fresh food section
those are 3 possibilities all of which involve the air flow into the freshfood side to be blocked off
Jul 18, 2011 | Refrigerators
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Jul 28, 2009 | Refrigerators
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Refig set at 34 degrees and it might be about 45 degres inside what could be the problem
How about the freezer? Is it cold (about 0 degrees Farenheit). If so, there's probably ice build-up blocking air flow from the freezer to the fresh food compartment. Even though modern refrigerators are 'frost free,' they're really not. Over a period of time, frost can build up in areas where air flow is restricted (like the door that controls air flow between the freezer and fresh food compartment). Take everything out of the refrigerator and freezer and allow both to defrost completely. To avoid an odor problem, clean out any food residue that may have been masked when it was frozen. Be sure to LEAVE THE DOORS OPEN while you're cleaning and until you're ready to turn the unit back on and put your food back in. Hope this helps.
Jun 11, 2009 | Samsung RS2534 Side by Side Refrigerator
Refridgerator not cooling
I always look underneith the ice box to see if cobwebs and dust buildup is clogging the fins and condenser motor. Clean that up all nice and she might work a little better. Look for frost on the back of the freezer, that indicates a bad heater. Listen for the fan motor in the freezer section. If it quits the cold air cannot get into the fresh food section. Check the damper (if applicable) to see if it is opening and allowing cold air from the freezer to get to the fresh food compartment. Look for to many food items in the freezer section blocking the cold air. If she needed freon you would fell absolutely no heat on the conderser coils below the ice box. MORE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Open Questions:
Refrigerators Logo
43 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
