Question about Whirlpool Refrigerators
I have a 1999 Whirlpool Refrigerator model ED252FXW01 that has stopped running. I cleaned the vents & it won't start again. Is there a reset button for this model?
    Sergeant:
  • 264 Answers
You can check down by the compressor however I don\'t think just cleaning the dust bunnies would trip a breaker. May sound stupid but I\'m married so I do stupid. Hook a small appliance to the outlet where you had it plugged in. There is a slight chance , and I am hoping you did unplug it before sticking your hands in there that the contacts in the outlet could be bad and or the wire that is screwed to the out let ( remove the cover be careful due to possible high voltage) that over the years the screw has loosened up and is not making a good connection. I HAVE seen this a lot especially if you have aluminum wiring as it is known for that and you have to every once in a while go through and tighten all connection or you could just pay an electrician to rewire the whole house with modern wiring. Also if you have no voltage check your breaker box to see if the breaker tripped there. The greatest power draw on a cooling device . motor, etc. is the start up that is when most power is needed. I have actually had two yes two fridges die on me until I found out that the lady we bought the house from had experienced the same problem and moved her fridge to a different outlet. Turns out the screw that holds the wire on was loose so there was a loss of amperage and that is really hard on a compressor or motor , relay or anything else is to starve it of power. It will destroy them over time. If you tilted the fridge or laid it on it\'s side ( never ever do) and if you do then I think the recommended time to let it set for the compressor to even out the Freon so it won\'t load up and shut down is 24 hours. If you notice on all fridges shipping boxes it says this side up. You could always try tapping softly with a small hammer or wrench on the compressor incase it\'s stuck. Then it could be the starter relay for the compressor also which is a set up including capacitors so wach out HIGH VOLTAGE is stored in capacitors even though the power is turned off. Good luck
Posted on Apr 17, 2014
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
catriver
  • 878 Answers
SOURCE: Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
Posted on Jun 28, 2008
aasc
  • 1606 Answers
SOURCE: My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Posted on Sep 06, 2009
dmftrucker
  • 1922 Answers
SOURCE: Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Posted on Nov 02, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Posted on Nov 13, 2009
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
Won't start
sounds like you have a bad motor,when it heats up it stops running and when it cools down it will run again but one of these times it won't run anymore until you change out the motor.when the motor gets hot you might smell a shellac smell,this is the windings on the motor heating up.part number 8528157 and it's around 120 dollars on the sears site
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-LSQ9549LW3/1198/0153200/W0312163/00005?blt=06&prst=&shdMod=watch this video to change motor
http://www.youtube.com/user/RepairClinic?v=Oeiyjt7807o&feature=pyv&ad=5457341981&kw=washing%20machine%20motor
May 07, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
I cleaned my Whirlpool SbS Model # ED25CQ coils underneath & accidently hit the fan & now it's not running. It seems the refrig & freezer are working so do I have to have a repairman out? Is...
You might have bumped the connector for the fan. yes you have to have the fan if the compressor is running, if not you will distroy the compressor.
Feb 20, 2011 | Whirlpool ED2SHAXM Side by Side...
My whirlpool vents ice up and won,t cool what part
This is probably not your problem this time, but it could become one in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have a Whirlpool refrigerator that has stopped
replace the electronics on the compressor --if you would like more tech diagnosis let me know
Aug 10, 2009 | Refrigerators
Fridge doesnt work but the freezer working as last week i switched of & its working good after but again the same problem fridge cool & temp 5
1. make sure frzr fan motor is running.
2.if so, the check air flow coming out of vent in freshfood side.
3.check for heavy frost built up on frzr rear wall panel.
4.make sure compressor and fan motor are both running.
also remove toe grill and clean condenser coil under refrig.
Jul 14, 2009 | Whirlpool ED2FHSS Side by Side...
Dryer runs when first started, quits halway through drying cycle.
High temp. limit is probably at fault and will need to be changed.
Jul 13, 2009 | Whirlpool Dryers
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
