Question about Dryers
Lg tromm wm2377cw
Lg tromm is grinding when it is spinning
  • 10 Answers
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
SOURCE: on my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Posted on Dec 21, 2009
SOURCE: LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Posted on Sep 19, 2010
KevinWhite
  • 1902 Answers
SOURCE: "LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Posted on Mar 27, 2011
  • 3921 Answers
SOURCE: My lg tromm washer sudenly started making a grinding sound and the drum does not spin. What is wrong?
You don't say whether the drum turns freely by hand.
It could be a broken spider or a seized or broken bearing or something come adrift in the tub causing it to jam.
The top will need to be removed for a closer inspection and it might be a simple and quick repair but from your description it will probably be absent from your home for a day or three and cost quite a lot.
Posted on Mar 01, 2015
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
Mar 01, 2015 | LG Tromm Front Load Washer And Dryer Set
LG tromm spins on washer,but doesn't on rinse and won't drain
ur confusing me its not suppose to spin first , first it rinses, then drains then spins
Jul 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm dryer electric sounds like bearings are starting to seize
if the bearing are going it will sound like a plain taking off grinding banging them you will end up with grease all over your clothes was told from an engineer once never put you m/c on any thing over 900 rpm spin speed as the bearings ar not designed to go any faster i have a hotpoint and its over 12 year old still sounds like new and never had a problem with it hope this help
Sep 23, 2012 | LG Tromm Electric Dryer
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
Lg tromm dryer making a thumping noise when running. What could this cost me to do myself or pay specialist to fix?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ssgf
Feb 07, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Aug 16, 2009 | LG Washing Machines
Feb 12, 2008 | LG WM-2277HW Front Load Washer
Dryers Logo
20 people viewed this question
Top Dryers Experts
