Question about Radio Communications
PLL ERROR GP 2000 VHF - Radio Communications
    Problem Solver:
  • 13 Answers
Phase Lock Loop error. This should be sent in for repairs to align PPL. Basically it is out of frequency which may have resulted in a jolt, drop or deteriorating component.
Posted on May 06, 2014
2 Suggested Answers
SOURCE: HOW TO OPEN FREQ
you need to have the radio programed with motorolas rss program.
Posted on Oct 14, 2008
How can I make the 19DXIV VHF capable
There is no way to make that radio VHF capable, CB radio's operate in the AM band, and most, if not all VHF radio's operate in the FM band. CB radio's are not capable of VHF frequencies either, VHF is considered around 40MHz and above, CB radio's operate between 26.965 MHz and 27.405MHz that is considered 11 meter band HF. CB radio's are not broadbanded enough to cover anything that far away, expecially the newer radio's, as most of them are controlled via a microcontroller and PLL tuning circuit. the 19DXIV is a great little radio, but will never be able to operate in or even around VHF. sorry.
Oct 21, 2012 | Cobra 19DXIV 40 Channel Mobile Compact CB...
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
Radio will transmit but not receive
first of all this could be a number of things i suggest you check the speaker first with a metre or any loose connections ,second it could be the pll chip that has gone check this with a multimetre also check jack at the back of the radio make sure there no short circuit cheers ei5glb
Oct 14, 2009 | Humminbird VHF-5a (10 Channels) 2-Way...
Mts 2000 vhf constant tone
The scan is on and you do not have a scan list programed.
This is the most common problem connected to your post. Hope that helps, Bill.
Jan 02, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
HOW TO OPEN FREQ
Oct 12, 2008 | Radio Communications
Cobra 2000 gtl
cobra 2000
am carrier 4.4 volts will not ajust...ssb carrier will 3.5 volt will ajust but max out put is only 3.5 volts.losses all voltage at ssd carrier when switched to usd r lsb
Jul 03, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Please Help me
MOTOROLA GP-2000 Programming Instructions
Switching between Dealer and User Configurations
- Turn off radio
- Press PTT + Monitor Buttom and + buttons together and turn radio on
- LCD Displays PRO-CLR
- To confirm switching to Dealer configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in Dealer configuration
From Dealer to User
- Turn off radio
- LCD Displays PROTECT
- To confirm switching to User configuration, Press PTT. To cancel, press any other button
- Turn off radio. The radio now operates in User configuration
ENTERING PROGRAMMING MODE
If the radio is turned on, turn it off. Press and hold the MON button and turn the radio on. A ringing tone will be heard,which indicates that the radio is in Programming mode. The PW and [] indicators are displayed.
EXITING PROGRAMMING MODE
To exit programming mode, turn off the radio
ACCESSING PROGRAMMING MODE PARAMETERS
In dealer config., Programming mode parameters are grouped into 3 (three) main categories.
RW = Radio Wide
Channel (001 to XXX) and
VFO (Variable Frequency Operation)
User + or - buttons to move from one category to another.
RW < >CH 001 < > CH 002 < > …. < > CH XXX < > VFO
Note : Radio operating in User Configuration is only restricted to PW parameters
Once you have selected the category and wish to view its parameter, use PTT or MON to move from one parameter to another.
Nov 06, 2007 | Radio Communications
Radio Communications Logo
255 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
