Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
After the load is finished I can shake the tub and hear water sloshing inside.
aborcass
  • 2651 Answers
SOURCE: Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Posted on Apr 12, 2008
beltronic205
  • 1460 Answers
SOURCE: THERE IS STILL WATER IN THE DRUM AFTER THE WASH LOAD HAS FINISHED
Check filter . clear..Good luck
Posted on Sep 29, 2009
  • 33 Answers
SOURCE: Our towels and clothes have a mildew/musty smell.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Posted on Oct 11, 2009
  • 441 Answers
SOURCE: Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Posted on Nov 11, 2009
bozcro
  • 867 Answers
SOURCE: After wash and drain, there is still some water
this is quite normal. but make sure the unit is level, the pump sucks up the most water then.
Posted on Nov 25, 2009
Maytag bravos quiet series 300.. I washed a blanket and it literally disintegrated into millions of pieces. How I clean it out from the inside basket. I cleaned it out of the tub but I'm sure there are...
I would fill the tub with water,like i'm going to wash a load,but don't put in any clothes .Run the complete wash cycle and see if the water all drains out.
Jun 05, 2014 | Washing Machines
KENMORE MODEL NUMBER 110.26912690 UNBALANCED DURING SPIN CYCLE
Open the lid. Remove clothes and drain tub. Reach in and give your tub a good shaking. You should hear a sloshing sound. If you don't hear sloshing your balance ring has somehow lost it's liquid and will need to be replaced.
Dec 21, 2012 | Kenmore Washing Machines
Hello, On Neptune washer serial # 34098916EF, Washer tub fills with about 2 inches of water within hours after doing a wash. When I spin the tub by hand, I hear water sloshing inside. Machine drains fine....
You have a bad water fill valve. Until you get it fixed shut water valves off at the wall so that you don't have a flood if the fill valve on the machine fails completely. Let me know if there is anything else I can Help you with.
Ken
Mar 17, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Stinky washer
you will always hear a bit of water in the tub after washing. buy a package of 3 tablets called AFRESH and follow the directions on the package. this product was designed specifically for the problem you are having. also, always leave the door open a little bit after washing. hope this helps.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Water stuck...
There is an internal overflow hose to prevent water from getting onto the motor and other electrical components. It sounds like the overflow system did its job.
The water you hear is likely one of two things: a small amount of water that is still in the tub, under the basket, which is nothing to worry about. Or, you are hearing the fluid (that is supposed to be there) in the balancer.
Feb 21, 2008 | GE WBXR2090B Top Load Washer
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
