Question about Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs
String trimmer tb20cs doesnt seem to be getting spark
Tried to ground plug to metal sometimes seeing spark somrtimes not
    Scholar:
  • 119 Answers
Hi
that is your ignition wire
along the ignition wire (sometimes called the lead wire)
there is a diode this diode is braking down
and is not repairable
just replace the complete ignition wire
that should sort out your problem
regards
Posted on Apr 17, 2014
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
The trimmer was running fine when I ran out of string. I add new string and now I can NOT get the trimmer to start! I tried unscrewing the spark plug, making contact to the metal of the engine and...
Adding a new string has nothing to do with your spark. If your checking for spark make sure the spark plug is grounded to the engine either use a screwdriver to help you ground it. Lay the plug on the screwdriver shank then pull the cord. If still no spark remove a wire of the ground switch then try again. If you get spark then the switch is the issue if still no spark then you may have to check the leg gap of the coil to the flywheel. Adjust to around 11 thou if you can. If still no spark then i'd go on record to say you have a faulty coil.
Oct 20, 2017 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Ryobi SS26 trimmer won't fire
Are you using a new plug,sometimes a used plug look's good,but doesn't work.
Jul 08, 2017 | Garden
Whats the gap on the spark plug on troy bilt tb20cs
Hello, Johnny -
The correct gap is .020" (0.5mm).
Link to specification page in owner's manual attached.
Troy Bilt TB20CS Operator Manual Specifications
Mar 06, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have no spark checked switch and replaced plug what else should I check
Check the coil. Pull the boot off of the plug. While holding the boot near a metal surface, darken the room and pull the starter rope. If you see a spark, the coil is good, if you don't, you just found your problem.
Sep 04, 2011 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Not getting spark
replace the plug and if problem presists contact your local small engines mechanic. you can even test your spark plug to see if its getting spark as well by.
easiest way would be to take it out of the engine, reattach the wire, and put the end on something metal, then oull the rip cord. if theres spark, then HOORAY! if not, get a new one or adjust the height of the existing one. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 30, 2011 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Gas powered string trimmer model TB20CS serial #1J145D80385 eng. will not start found there was NO spark replaced with new spark plug still no spark then replaced spark module assembly attached electric...
hi there , pauly46 here
have you tried taking the kill wire off at ignition module and retry for spark - kill wire might be grounding or a faulty kill button or switch ,
make sure if the module had little spacers on the coil mounts to make sure that the magnet actually passed under the coil and trigger properly
air gap is usually 0.010 thou
other than that you may have a fauly coil from new
only way to know is to have your local shop test it for you ?
cheers hope it helps
pauly46
May 05, 2011 | Garden
I have a troy bilt trimmer model tb20cs. has been laying for about four years. gave it a good cleaning ,new spark plug amd fresh gas. starts up fine and idles a short while then cuts off. If you try to...
Carburetor needs cleaning and probably diaphragms. Be sure to completely disassemble and pay very close attention as to where each diaphragm and gasket goes also make sure you remove the needle valve and clean screen.
Aug 25, 2017 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Home lite String Trimmer Won't Start
be sure your kill switch is set to run positon and the wires from it arent grounding theirself out . Make sure your spark plug is
grnded to metal when you check for spark.(ground to head away from the spark plug hole
You may have a bad ignition module if you still have no spark or the flywheel keyway has sheared for some reason throwing it out of timing.(removal of flywheel is required to see if the keyways are aligned flywheel and crankshaft)
If your flywheel seems tight then you may be ok
not a high failure rate but it has happened.Gap your plug at .030 then.025 see if that makes a difference? keep going to a smaller gap to show you may have a weak module not able to jump a wider gap.
just a couple things to check hope this helps maybe
May 31, 2009 | Homelite Mighty Lite Lawn Trimmer
Troy Bilt Tb20cs 2 Cycle 31cc Gas String Trimmer 17" Cs Logo
91 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
