Dashlights dont work cant figure out which fuse run the dashlights
Library has free access to automotive database. 10 cents a page to print. a 12v test light is used by technicians to verify fuses. you can eliminate or verify quickly that a fuse blew. but also remember power feed to that fusebox comes first from the power distribution center under the hood. it also has fuses and relays. if all the bulbs went out now, then you should pull the cluster. when i worked on these when they were new, some cluster repair was done by sending the cluster out to be fixed. hope its just your bulbs.
