Question about Kitchen Ranges
Maytag how to unlock oven
The control lock is on and I do not know who to unlock the control lock
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Check your owners manual, it should tell you. A lot of times it is just holding down a button or two for a couple of seconds to get it to unlock. If you dont have manual try contacting maytag with model# and they should be able to help you.
Posted on Apr 17, 2014
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
How do you unlock the control locked function on a Maytag Gemini elec. range?
If its a self cleaning unit, try start the self cleaning cycle, then cancel it. If that doesn't work let the self clean cycle finish completely and it should go back to normal.
Mar 15, 2015 | Maytag Kitchen Ranges
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Cannot unlock oven door
  • Here it is!
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    What does the sign "control lock" mean?
    Here is what the manual for your oven says about control lock.
    Let me know if you have questions.
    Control Lock
    The Control Lock shuts down the control panel pads to prevent
    unintended use of the oven(s). The Control Lock will remain set
    after a power failure, if set before the power failure. The only time
    it is not available is during the Sabbath Mode or Self-Clean cycle.
    When the control is locked, only the TIMER SET · START, TIMER
    CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
    CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
    function. On double oven models, CLOCK SET · START will also
    function.
    The Control Lock is preset unlocked, but can be locked.
    To Lock/Unlock Control: Press and hold CONTROL LOCK for
    about 3 seconds, until “CONTROL LOCK” and a picture of a lock
    appear on the display. Repeat to unlock and remove “CONTROL
    LOCK” from the display.
    May 13, 2010 | KitchenAid SGL OVEN T/C
    How do I unlock the key pad? The display shows locked and I don't know how it locked.
    Here you go.
    The Child Lock shuts down the control panel pads to prevent
    unintended use of the microwave oven.
    When the control is locked, only the Vent Fan and Light pads will
    function.
    To Lock/Unlock Control: The microwave oven and Timer must
    be off. Touch and hold START for 5 seconds until 2 tones sound
    and a lock icon appears on the display. Repeat to unlock and
    remove the lock icon from display.
    May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    MY OVEN IS LOCKED
    unplug the oven wait 5 minutes and plug back in usually that resets the controll panel then it will unlock
    Jan 21, 2010 | Maytag MEW5527B Electric Single Oven
    We had a lighting storm and the current went off. When the current came back on the oven door locked and now wont open.
    The lighting has sent a surge though the control board, in return, causing a short within the main control circuits.
    The EOC(electronic Oven Control) is unable to send the unlock command. it is shorted at this time. replacing this failing oven control(EOC), will restore the normal functions of this unit.
    Normally, you would recive a door lock malfuction error code in this case to signal a door lock mechinism failuer but, in this case, the control has took a direct hit and, it is unable to fuction correctly.
    Jun 15, 2009 | Maytag CWE4800A Electric Single Oven
    Can't Unlock oven doors after "self-Clean" maytag double oven
    I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
    Dec 22, 2008 | Maytag Kitchen Ranges
    Kitchen Ranges Logo
    81 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
