My rinai gas heater is not reallly lighting up though gas flow seems alright
The ignition works and there is flame but the element does not stay lit
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
Gas also requires oxygen to burn, perhaps there is an issue in an air feeder or mixing valve some where in your piping or if there is an inlet for air ensure that it is not obstructed. Using any combustion device in a confined space can be problematic for health reasons and the combustion process due to a finite oxygen supply. I hope this helps your investigation.
Posted on Apr 18, 2014
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Water heater flame problem
Check your exhaust, see if its clogged or blocked, clean the flame sensors, I that does not work, then your gas valve is starting to go bad, there is a cap on it if you take the cap off you can turn the gas flow down a little bit,
Jul 14, 2013 | RTO Atwood Water Heater - 6 Gal LP
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
My pilot light wont light and my heater will not stay on.The ignitor is cliking as if it works but will not ignite and if I manually light it the lighter will not stay on.
Essentially all gas devices regardless of which gas used, are equipped with a thermocouple that monitors the pilot light's condition and if it fails, it will not permit the main flame to light or the pilot light to stay lit. In your case, it may be that the TC failure also prevents the lighting of the pilot light.
May 20, 2011 | Endless Summer 200209 Open Flame Patio...
Rinnai gas log heater (royale) keeps cutting out. now it wont stay on at all. the ignition is fine, the gas flow seems fine and the fan works fine. we vacuum the dust out regularly
When you say "it won't stay on at all." Do you mean the burner and the pilot flame shut off together or does the pilot remain lit? Is the unit showing any Fault Codes on the LCD display?
Apr 03, 2011 | Rinnai Heating & Cooling
Just installed a 425 hn, the igniter clicks and the pilotflame goes on and off at the same rate as the igniter clicking. The main burners will not kick on. Checked all the electrical connections, checked...
I am not aquainted with the Bosch..... But it is a heater. I am going from past experience with gas furnaces and how the process works..... You said that you can get the pilot to stay on if you unhook the Main Gas Valve wire. Do you have 24 Volt power on that wire to Common? Does this have a Flame Sensor? Maybe it got damaged. Does it have a good ground from the burner to the ignition control module? Does that wire to the electro valve go into a plug that plugs into the ignition control.... Maybe that pin is not making contact to the board. Hope this helps If no one else answer right away repost Or call and see if you can get Tech support from Bosch..... I know how frustrating it is you buy something brand new and it doesn't work
Feb 01, 2011 | Bosch 425HN NG Tankless Water Heater
Kenmore gas dryer igniting problem
check the flame sensor. it could be the problem since it would ignite first then if the flame sensor is mal functioning, it would indicate a "no flame" signal that would cut off the fuel solenoid. then it would shut it off.
Feb 13, 2008 | Kenmore 63942 Dryer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
