Question about epestsolutions Curtis Dyna-Fog Hurricane with Float
There is only air coming out and no mist
When the machine is turned on there is only air being blown out and no mist is there a simple solution to fix this or is my machine broken
Have ultrasonic cool mist humidifier.....it is blowing cool air ...but no mist...what could the problem be?
It has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up.
Feb 06, 2017 | Humidifiers
I have a 93 4runner v6 manual. I went to turn the heater on the other day and no air was coming out of it but when I started driving down the freeway air started coming through the vents. When I stop
sounds like your fan is either jamned, burnt out or even frozen, you might be lucky and find its just a blown fuse, you'll need to check your fuses box then start investigating if the fan turns freely or not
if you put the air on recirc you might be able to stop cold air blowing in when you are travelling. if you are waiting for a garage to sort out the fault then get a fan powered by the cigarette lighter, air moving over the window should at least keep mist clear even if it doesnt defrost it
Nov 09, 2011 | 1993 Toyota 4Runner
I got the Crane Cool Mist humidifier - drop shape in blue. Although i can feel a small amount of air coming out from the spout, mist is not visible, not a bit.
if you can hear the fun noise, you need to check major circuit, should be bad capacitor. if no noise at all, replace the fun.
actually they have very good customer service. just contact by email or phone, tell them what's happened, they should give you a RMA number, put the tank cap and cut small piece of power cable, send to them, you will receive a brand new humidifier within couple weeks. even your machine slightly out of warranty.
Apr 02, 2011 | Crane Humidifiers
I do daycare a parent brought me the nebuilzers/breathing machine it sounds like is on but I see no mist or vapor I disesemble to see if i feel air and i do but i see no vapor mother tells me it just...
Is there distilled water or liquid medication in the container? If not, all that will come out is air. There should be an adjustment valve on the hand-held part of the nebulizer, that adjusts the liquid flow and turns it into a mist.
Apr 01, 2011 | Humidifiers
Why does my humidifiers does not have any smoke coming out?
My Guess is that the reletive humidity in the room is not low enough to see any vapors coming from the machine. Normaly you won't see these anyway. Some models in the stores seem to make more mist than what you get at home. If the humididty level in a room is close to what is coming out of the machine there will be no signs of any mist coming out. Just make sure the filters are clean and check and make sure the water level is going down on the machine and this will tell you its workin. the faster you are using the water in the tank the more you are putting in the air! If this is a hot mist machine then I would say the heating element in the machine is not working.
Nov 16, 2010 | Venta Airwasher VS370 2 Gallon Humidifier
2003 883 sportster that has oil coming out of the carb
All Harley engines built after 1994 have been what we call "head breathers". In other words, the crankcase ventilation has been routed into the breather through the heads. The requirement of the crankcase pressures being released into the intake system is the results of EPA anti-pollution regulations. Harley moved the vent from the lower crankcase to the heads to decrease the amount of oil blown out by the ventilation system. But, there is a certain amount of oil mist present in the expelled air. The mist will collect in the breather over time and will eventually drip out of the air cleaner. Regrettably, this is a fact of life with a Harley engine and it's design and it is normal.
Now, you can clean the air cleaner on a regular basis to keep the oil out of the air cleaner or you can purchase a kit that exhausts the crankcase pressure (and the oil mist) somewhere other than the air cleaner. I thnk Kuryakin has a kit.
Good Luck
Steve
Jun 06, 2010 | 2003 Harley Davidson XLH 883 Sportster
Very little mist coming out
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Jan 25, 2009 | Mabis CompMist Compressor Nebulizer
Oily smoke/mist coming from under bonnet from large pipe feed
That is the R12 Refrigerant from the AC System. A Seal has Blown out of the AC Compressor. You should be ok driving to a Garage , Just keep the air off and watch it Close.
Jan 21, 2009 | 1999 Saab 9-5
Air Conditioner Smoke
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Jul 09, 2007 | Maytag M3V08S2A Air Conditioner
epestsolutions Curtis Dyna-Fog Hurricane with Float Logo
223 people viewed this question
Top epestsolutions Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
samiya_jahan
Level 1 Expert
Are you an epestsolutions Event Planning and Celebration Expert? Answer questions, earn points and help others
