Question about Whirlpool Washing Machines
Whirlpool cabrio wtw6300swo ul
My washer gets off balance and displays a ul code
    Scholar:
  • 46 Answers
Hi, the UL code on your washer means unbalanced load. If this is the first time it has happened just pause the washer and redistribute the clothes and continue the cycle. If you get this error a lot there is a suspension rod kit available for the issue. Part # W10189077. Also Whirlpool has had issues with the tub bearing that can add to the out of balance problem. If it makes a loud roar while spinning then it needs a bearing kit also. Your looking at around $170.00 for the suspension rod repair and $ 270.00 to have both the the bearing kit and rod kit replaced. Hope this helps.
Posted on Apr 17, 2014
  • michelle ianno
    michelle ianno Nov 03, 2014
    can you please tell me the cubic feet on the WTW6300SWO cabrio washing machine?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 92 Answers
Uneven Load
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Ul is displayed what does this mean
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Jun 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
May 28, 2012 | Whirlpool Washing Machines
No matter what I do my cabrio washer get ul code. I have cleaned and regreased all pivit points as recomended
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to re-balance the load.
If the mini-cycle is unsuccessful, ul will flash until the door lid is opened, allowing the customer to view and redistribute
the load. Not sure why you would lube anything for this fault code. What may be the problem is the struts that steady the washer drum, they are in effect shock absorbers, they are likely the source of the code.
Jan 27, 2012 | Whirlpool Washing Machines
My washer keeps stopping at the spin cycle and says UL for uneven load. The load is not uneven and evey load does this
Hi.
UL is displayed when there is a balancing problem or when balancing sensor is defective.
The first thing to do is checking floor level and putting the machine at balance as explained in the user manual also try distributing the load
. If that does not work there are internal faults that may trigger the fault code. The balancing sensor and the electronic control board must be tested. The machine must be disassembled to locate the problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Jul 24, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is blinking uL HELP!
Hi. uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalanced the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
Aug 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer will not stay balanced and show on UL code.
the repair man says i need to replace the inner tub for 299 dollars with a total price of 424 and its only 4 years old
Jan 19, 2010 | Whirlpool WTW6400SW Cabrio Washer
Washing Machines Logo
242 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
