Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a Whirlpool Cabrio washer Model number WTW63003WO that gets off balance and displays a UL code.
    Novelist:
  • 150 Answers
It's important to check the level of the unit, and assure all adjustable feet are firmly planted on the ground first. A very common problem with these units are the suspension dampening rods, when they get weak they allow the tub to move around too much while spinning, and sometimes washing. A simple test by an experienced technician who knows what to look for would be to reach into the wash basket while the machine is empty and off, and push the tub all the way down till it stops, the technician will be looking for the amount of resistance it takes for this to happen. The easier it is to push the basket and tub assembly down to the end of it's travel the weaker the suspension rods are. At least one update to these suspension rods have been made, suggesting the current replacements are stronger. Part# W10247710, based on a model number of WTW6300WW0. Pleazer Appliance...
Posted on Apr 17, 2014
3 Suggested Answers
SOURCE: My whirlpool cabrio washer will not stay balanced
the repair man says i need to replace the inner tub for 299 dollars with a total price of 424 and its only 4 years old
Posted on Jan 19, 2010
GodBlessU
  • 3513 Answers
SOURCE: i have a whirlpool cabrio washer wtw6200swo when
Hi
UL error means unbalanced load. In this case you have to rebalance the load and start it again.
Please check the link for whirlpool cabrio washer fault codes and the resolution that has been given in the chart:-
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 19, 2011
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
May 28, 2012 | Whirlpool Washing Machines
No matter what I do my cabrio washer get ul code. I have cleaned and regreased all pivit points as recomended
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to re-balance the load.
If the mini-cycle is unsuccessful, ul will flash until the door lid is opened, allowing the customer to view and redistribute
the load. Not sure why you would lube anything for this fault code. What may be the problem is the struts that steady the washer drum, they are in effect shock absorbers, they are likely the source of the code.
Jan 27, 2012 | Whirlpool Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is blinking uL HELP!
Hi. uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalanced the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
Aug 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer will not stay balanced and show on UL code.
Jan 19, 2010 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
