Homelite Mighty Lite Lawn Trimmer  Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ut20816 i have ut20816 weed eater and wont spin
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jun 18, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737507
Points
36074
Where the motor connects to shaft, inside there is a cable that goes from motor shaft all the way down the tube to the end of the wip. The cable likely came off in one of the two places.
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 • Garden
    Weed eater head spins on its own, no power.
    check the compression on your weedeater low compression will cause this
    New husqavarna head wont turn
    Will spin or wont spin.? Slight confusion in your question.
    3helpful
    2answers
    2helpful
    I have weed eater model FX26SC it starts and when I put it to run the weed eater doesn't spin but is running
    Either the clutch is worn out or the flexible drive shaft is broken. Either repair is likely to cost almost as much as a new unit.
    May 16, 2010 • Garden
    1helpful
    Ryobi weed eater head won't spin
    Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
    Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
    rotate attatchment head slightly while inserting driveshaft
    Jul 30, 2009 • Garden
    Top Homelite Garden Experts
    Jay Finke
    Jay Finke
    Thomas Perkins
    Thomas Perkins
    Sean Wright
    Sean Wright
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
