Question about HEWLETT-PACKARD G42-415DX Laptop
Totally dead The computer stopped working and doesn't respond. There was no warning, it just won't turn on. Something is rattling inside.
  • HEWLETT-PACKARD Master
  • 17,326 Answers
Was it ever dropped? The rattle is concerning. There is almost no way for you to do anything about this without taking it apart. That is not something that is easy to do though. Can you describe the rattle? Is it heavy sounding or light sounding? What is the location? You can take the covers off the back for the RAM, Hard Drive and battery and see if you can see anything rattling. See if the memory chip is lost inside. That could cause the problem.
Posted on Apr 17, 2014
On and off switch won't work LEDVDD2488A-B
ITS MOST LIKELY a problem in the power supply of the unit or something connected to it that is stopping the set from coming on.
If total dead look for a bad fuse or even damaged parts on the board.
Dec 18, 2012 | Televison & Video
My controller won't turn on. There's something that sounds like it's rattling in it, but it's brand new, out of the package literally 5 minutes ago.
If you hear rattling, something has probably come off on the inside. Must be battery connections since everything worked except powering on. If you bought it from ebay, contact the seller right away and have it replaced. If you bought it locally you can easily get a replacement.
Dont open it or you risk not getting a replacement.
Nov 17, 2012 | TTX Tech Black Wireless 2.4GHZ GamePad...
MY tv is not getting turned on Manually/ Remotely..!
First if now total dead it has a fuse inside to look at.
Jun 14, 2012 | Venturer 19 inch flat screen TV
My ScanDisk cruzer micro 2.0 stop working. The orange light won't turn on and no respond. I don't need to get another ScanDisk. I just want to have all my documentations. Is this situation fi
I would try several different USB slots if you haven't already. Unfortunately, if it doesn't light up, there's not much you can do, other than take it to a specialist. Sorry.
May 02, 2012 | Computers & Internet
My Zen seems to be totally dead after loading it with mp3 tracks. I've recharged it to no avail, it won't switch on or reset, and it is not recognised by my computer when connecting via a USB...
hi your not the only one i got mine for my birthday 8 weeks ago and now it dont work its like its dead this zen v plus to is like not the best thing to have all i see is people like me having some sort of prob with it
Sep 20, 2011 | Creative Labs ZEN V Plus MP3 Player
My daugthers 2003 Olds Alero (3.4) isn't starting. Turning the key doesn't ingage the started. First time: I went in and tapped on started and couldn't get anything to happen then all of a...
This sounds like there is a dead spot in your starter. The easiest way to resolve this issue is to replace your starter. Many times, if you take a lot of short-distance trips over the life of your car, the wiring inside the starter itself will wear (short trips means starting it more often, causing a lot of wear over time). Then the inner wiring of the starter wears too much, it forms a "dead spot" -- when the starter is stopped at a very specific spot i will not form the magnetic force needed to torn the starter motor. This is a common issue which can be dealt with for a time if you have to save the money to replace the starter. Tapping the starter, or arcing it with a screwdriver makes the inner workings of the starter jump a little, allowing it to move out of the dead spot and kick over as normal, but it is only a temporary fix. Unless you refurbish electronics for a living, it is very unlikely that you will be able to repair the starter on your own, and such a repair takes some time, so you are better off to replace it than try to repair the starter itself.
As long as the starter does not happen to stop in the dead spot, it will work as normal ... but in time the dead spot will spread, causing the issue to worsen. You can keep forcing it to turn with the two tricks you used until you have had the opportunity to earn the money to replace the starter (or until you have a day off to get the repairs done) .. but over time this can cause more damage to other parts of the car, so I recommend replacing the starter as soon as you can.
Jun 07, 2011 | Oldsmobile Alero Cars & Trucks
I have a soniq b100 disc player, which only responds intermittently after only 6 months since purchase. The player won't turn on, the buttons on the main unit have stopped responding and the remote...
Sorry, no there isn't much you can do at a consumer level with this player, except, if you still have a manufacturer's warranty, taking advantage of it and sending the unit back for warranty repair/replacement (whichever they suggest to you). It is clearly malfunctioning, beyond user control - send it back as a warranty claim (if you still have one on this model). It won't cost you in repairs that way.
Don't put up with a defective product, send it back - get it fixed under warranty free of charge (if applicable), or the unit replaced (again, if under warranty, free).
It won't cost hundreds of dollars and shouldn't take forever to resolve this simple case. Good luck. This is something the manufacturer should worry about; not you.
May 06, 2011 | Televison & Video
Kinyo t3100 bass speaker has a rattle when playing music
try turning the bass down and make sure that the rattle is inside the speaker check around it and see if its not something nearby the speaker it could be something came off inside.
Oct 08, 2009 | Kinyo NB-100 Computer Speakers
HEWLETT-PACKARD G42-415DX Laptop Logo
20 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
