Question about Fisher Audio Players & Recorders
Fisher ca 880 specs
Replaced left side fuse and now when i turn it on the left side power dial on the front shoots all the way up to 100 wats and there is a buzzing nosie and if i leave it on long enough something starts burning
  • Fisher Master
  • 15,628 Answers
There is a bad driver for the final amp. The oscillation is called motor boating. You need to take it for repairs unless you know how to solder, have test equipment, want to buy the schematic and the parts.
Posted on Apr 17, 2014
Won't start. Replaced battery. Still not working. No power at all. No interior lights on dash board, no interior lights. When ignition is turned nothing happens. HELP!
I would first check to see if the negative battery cable is grounded. Connect a jumper from the NEGATIVE side of the battery to the frame and check for power. The more likely cause is the main fuse in the fuse box under the hood . The box should be in the left front and the fuse should be labeled 100 or 120 amp. It may require removing the entire box to get it out as it may be bolted in.
Oct 18, 2014 | 2003 Toyota Highlander
We replace the power steering motor on our 07 chevy hht and its still the same hard we replace the side panel fuse but not sure wat fuse need to be change under the hood panel
you need to bleed it take off filler cap .check the level of fluid is ok start the engine now to bleed it turn the steering full lock left and right a few times then replace the cap.
Dec 23, 2013 | Cars & Trucks
Fisher equalizer-2322
"Rec" is considered a send (output from Fisher to an external device) and PB (playback) would be an input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
Dec 12, 2013 | Fisher Vintage Ca-880 Integrated Amp...
Fisher equalizer 2322
"Rec" is a send (output from Fisher to an external device) and PB (playback) is a input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
Change Fuse on Fisher Paykel Dishdrawer
I have a single drawer F&P dishwasher. This morning a safety switch trigged. This afternoon when I went to use the dishwasher found that it had no power. There are no lights and there was a smell of something burning. The power outlet has power. Can you help?
Feb 08, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
On the Fisher CA-9435 i dont get sound from speaker outlets but hook it up to surrond or center speaker and clear. how can i fix this problem?
i would take off the cover and try checking and replacing the fuses mental note unplug the unit before such there is going to be two fuses side by side change them both if that dont fix the problet then it is a relay that is bad
Jan 20, 2010 | Fisher Audio Players & Recorders
RE: Fisher Model CA-270 - 480 watts.
These units use amp-pacs for the output stage, if I remember correctly. All in all, the unit will require some diagnosis to determine the problem with the power supply and the final output stage. The total cost of repair easily could exceed $125. You can probably replace the unit with a better one for not much more.
If you would still like this unit repaired, please indicate where you are in the country and I'll try to find a shop for you.
Dan
Aug 12, 2009 | Audio Players & Recorders
Turn signals dont work 97 Geo Metro
we found the flasher curcuit had no power to the hot prong. So my friend wired the flashers hot prong into the radios fuse curcuit to get power to it and put a separate 10amp fuse on the new lead.
Jan 22, 2009 | 1991 Geo Metro
Need to reset fisher paykel DEGX1
That appliance is fairly complicated. If you want to service it yourslef, my honest answer is to get the factory service manual from fisher paykel. You can get it here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Dec 12, 2008 | Fisher and Paykel DEGX1 Electric Dryer
102 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
