Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Electrolux washing machine wont spin all the way
Wont do full speed spin at end of cycle. will spin full speed under diagnostic mode and throws no errors. Motor and tach resistance check ok. Did many clean cycles, soap not the issue. Tub drains fine. door locks fine.
  • 2 more comments
  • jim crow
    jim crow Apr 17, 2014
    Noticed cloths were very wet when washer signaled load was done. Tried to run just the spin cycle. the drum would run CW, stop, then run CCW, then stop, etc.... this would continue back and forth but would never progress to a full speed spin cycle. I checked all the usual stuff.... drain was fine, door was locked, soap was not a problem. Pulled the back off the washer and checked the belt, bearings and resistance of the motor and tach, all were fine. Found the tech data sheet under the lid and ran the diag test. the drain spin test would get the drum to spin full speed but gave the motor controller error code. I pulled the motor controller board and found dead bug goo all over the circuit card, possibly shorting out some of the ICs. I used proper static protection, removed the board from the plastic case, cleaned the board using ESD best practices and re-installed everything. Now the unit still wont run spin cycle to full speed but I don't get any error codes. I can even leave the wet load in the tub, go to the diag test and manually run the drain spin test to dry the cloths.
  • W.L. Apr 19, 2014
    Any progress?
  • jim crow
    jim crow Apr 24, 2014
    Seems like the full speed spin cycle works some times and not others, may be load size dependent now. Like larger loads will not spin up full speed, they just get to the spin cycle and the drum just does the slow CW then CCW then CW spin but never fully spins up. Unit will run spin cycle empty and with smaller loads and I still have not seen the first error code after I cleaned the gunk off the motor controller board. I am thinking I will just purchase a replacement motor controller board and hope for the best.
  • jim crow
    jim crow May 03, 2014
    I bit the bullet and purchased a new motor controller board, swapped it out and everything seems to be working fine now. Must have been some IC level failure in the MC that was not sensing rpm's, current, load, etc... correctly and would keep the drum from fully spinning up.
  • 2,509 Answers
Not a solution, but I wonder if it thinks you've either selected no spin or it thinks the machine isn't drained and so won't spin or it thinks the load is unbalanced. You seem to have done everything logical so far.
Also look at all all connectors
Logic seems to dictate that if the motor/motor drive functionality and other diagnostics don't show any problems (although I must admit if it were possible I'd like to try another motor control board just to convince me it wasn't implicated) then it must be a logic/ sensor problem and maybe diagnostic mode doesn't check all sensors in the same way as would happen in normal use? Sorry I can't be of more help. (The motor brushes are probably ok but I'd check them anyway while you are in there) Do let us know if you find anything.
Posted on Apr 17, 2014
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
SOURCE: How to run tHe self cleaning cycle on electrolux
http://www.ehow.com/how_5640173_clean-electrolux-front_load-washer.html
Posted on Apr 29, 2010
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
torres No9
  • 27 Answers
SOURCE: Electrolux EWF 1495, spin does not work in quick60 cycle
it,ll will be a circuit board fault, probally the motor inverter board there is 3 pcbs in this model.
Posted on Jun 25, 2010
BIKER T
  • 909 Answers
SOURCE: Hi, I have an Electrolux
Im taking it that you have a squirrel cage motor.(motor without bruhes) Locate the capacitor and replace it. Most of the time its the capacitor that has malfunctioned and that will stop the spin cycle. If you have a soft start.(an electronic control), then check the brushes. Possibly need someone to help as the motor will need to be removed to gain access to the brushes. Check length. must be at least 25 mm.(otherwise not enough tension). Make sure power is pulled out when doing this repair.
Posted on Sep 05, 2010
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Why wont my ewf 1080 electrolux spin
Most likely the washing machine is stuck in Hold mode. Check if you have the spin speed knob at the correct setting.
Manual is available from here
http://www.manualslib.com/manual/616814/Electrolux-Ewf-1080.html#manual
Check the parts and schematics at this site
http://spares.bigwarehouse.com.au/index.php?cPath=64689_77309_77544&sort=2a&page=1
Aug 29, 2014 | Electrolux Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Wfc7500vw spins but not at high speed on final spin
This is a common problem with the Whirlpool front load machine. The motor control board goes out but the new ones have been redesigned. You will need to replace the control board. Here is a link to the control board you need.
Oct 17, 2012 | Whirlpool WFC7500VW Washer
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
152 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
