Question about Dell KDA1 Color Laser Printer 5100cn PC 11409 Refurbished Mfr P
Wont print in color - Dell KDA1 Color Laser Printer 5100cn PC 11409 Refurbished Mfr P
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
Wont print in color it only prints black and gray
  1. Click on start and go to printers and faxes
  2. Right-click on the icon for hp officejet 4215 printer and go to printing preferences
  3. Click on the color tab
  4. There are two options print in color and print in grayscale. Choose print in color
  5. That should solve the problem
Jun 27, 2011 | HP Officejet 4215 All-in-One Color Photo...
My hp7200 wont print color
Your printer wont print paper because you need to put color paper in your printer
May 16, 2010 | HP OfficeJet t45 All-In-One InkJet Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
OFFICEJET 5610 COLOR AIO Printer: I have an hp 1530 that wont print in color after w...
Open HP solution center.
click on settings >>> Printer settings >>> click on Color tab..
select print in color. Click on OK.
Now try to print
May 07, 2010 | HP Officejet 5610 Color All-in-One Printer
I cant print in color
For reasons known only to Brother you are unable to print ANYTHING if you are out of any color of ink. If you are out of black and need to only print in color it WILL NOT work
Feb 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
Wont print color will print from black cartridge only both are ne
Try <CTRL> P
Find the color option:
Make sure that you are not printing in gray scale:
Oct 05, 2009 | Lexmark Z611 InkJet Photo Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Epson 9800 wont print large images
make sure that the printer is not managing color by selecting "off (no color adjustment)" in the Printer Color Management option of the printer settings.
Could be a head clog, could be ink starvation, could be head overheating...
How old is it ... ?
Fame !
Jun 25, 2009 | Epson Stylus Pro 9800 InkJet Printer
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Dell KDA1 Color Laser Printer 5100cn PC 11409 Refurbished Mfr P Logo
14 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
