Question about Toshiba SD-V291 DVD Player/VCR
Dvd on toshiba sd v291 wont play. once the door closes the dvd does not spin or won't read
2 Suggested Answers
SOURCE: won't open...
Hey this is a great site!
I was having a similar problem with my Toshiba SD-K860. Bobbyj, thanks for the link to the SD-4900 service manual, it was extremely helpful even though it was a different model. I could not find an emergency eject pinhole, and leaving the unit unplugged for a while did not help (two suggestions found on other sites), so I simply took the whole thing apart, got the disc out, found the eject slider on the bottom of the tray, massaged the tray open and closed, and put everything back together again. The connections were solid and the belt was in tact so everything seemed to be fine. Once I reassembled and powered it back up it worked again!
I posted a more detailed solution on my problems to solve site, which is similar to this one:
http://problemstosolve.com/solved/toshiba-sd-k850-wont-eject-solved/
Posted on Jun 10, 2008
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
What is the manu code number for this unit
hi! i have here a couple of codes here for your toshiba, just try them,1154, 2093, 3099, 1158, 2094, 3098, 1338, 2094, 3149,1116, 2054, 1293, 2210, 1294, 2210, 1345, 2231, hope this helps!!!! goodluck!!!
Jun 09, 2010 | Toshiba SD-V291 DVD Player/VCR
The dvd has a tape in it and after playing it we tried to open it up to take it out and it will not open up...have tried to shut it off and still no results
will have to open case and turn the worm gear to the tray loader mechanism manually. this will cause take to slowly eject.
Dec 21, 2009 | Toshiba SD-V291 DVD Player/VCR
Dvd loads but then says: no disc
try cleaning the lens and try other disc.
May 27, 2009 | Toshiba SD-V291 DVD Player/VCR
We hooked out Toshiba SD-V291 up to our Sony TV through a Direct TV Cable box. We get the sound when we play a DVD but no Video. We hooked it up with an SVideo cable and input/output cables. What are we...
I just had the same problem, and I am using rca blue, red and green cables for video. I unplugged them and plugged them back in again a couple times and it finally worked. I have had this problem before with another dvd player, don't know why. Hope this helps.
Chris
Dec 27, 2008 | Toshiba SD-V291 DVD Player/VCR
Toshiba sd-v291
Click on the link below then type in your model number or you can click on the second link for a direct download
http://www.tacp.toshiba.com/customersupport/
http://www.tacp.toshiba.com/tacpassets-images/models/sd-v291/docs/sd-v291_om_e.pdf
Apr 20, 2008 | Toshiba SD-V394 DVD Player/VCR
Dvd player not working
If the disc isn't spinning, and you have cleaned the lens (using a proper method) then it is likely that the laser has failed. The disc usually won't spin until the laser has sent/recieved a pulse from the surface of the disc. A new laser is usually about the cost of a new player.
Sep 10, 2007 | Toshiba SD-4900 DVD Player
Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Aug 13, 2007 | Toshiba SD-P1400 Portable DVD Player
Toshiba SD-V291 DVD Player/VCR Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
