No power at all after returned from vacation.
Likely a power surge hit your house while away. This happens when power turns back on or lightning hits close to your house. If insured, call insurance company about it. You may be covered for replacement or have deductible applied. Small appliances like this are most susceptible to power surge. There is not enough protection designed in.. The best protection is surge module on main breaker panel or buy a protected power strip to protect high value electronics.
SOURCE: Remote Code for HDX500/I
Get a Logitech Harmony 880 universal remote. I have it operating my home theatre, TV, iPod and cable just fine - all with one remote.
SOURCE: Panasonic SC-HT75 Home Theater system
with the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
SOURCE: I have a Panasonic SA-HT650 Home Theater system
A power source problem. Means there is voltage measured at the output/speaker cable connections. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the power ac power source from the wall is wired correctly and has proper voltage and grounding.
SOURCE: i looking the manual for panasonic home theater
http://www.panasonic.ch/doc/8301_8400/8308/userguide/userguide_2_sc-pt150eg-k_-.pdf
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-BTT350-Home-Theater-Systems-manual/id/23826dj494/t/2/
If it has no obvios way to change its input voltage to 220V on the back, no.
