Question about Gateway Nv54
Help my NV54
Battery dead will not operate with just power cord?
    Sergeant:
  • 258 Answers
Most laptops have the ability to operate with just the power cord. Have you tried it? If it won't work, then that's another issue.
Posted on Apr 17, 2014
Battery went dead, now will not turn on even with jist power cord
Oh, oh. Check the connection. If a light turns on as you wiggle the connection, then the plug needs to be re-soldered. Not an easy task, but take it to a PC shop for an estimate.
Apr 16, 2014 | Gateway Nv54
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
My Sony laptop is not charging when it is pluged in on to the electric oulet
If the battery is not charging when the power cord is plugged in then the battery is completely dead and needs to be replaced.
Are you sure your power cord is good and that you are not operating on battery power?
Take the battery out and see if the laptop stays on. Or you can reboot with the battery out and the power cord in. If it fails that means the Power Cord is the issue and you were working off the battery.
If you leave the power cord off and insert the battery, then reboot. If it boots up and stays up that means the battery has some charge in it. If it does not boot up or boots and shuts down, the battery is drained and you will need another one if the power cord is good and it's not charging.
Mar 25, 2012 | Sony Computers & Internet
Why is my acer emachine charging blinks in red
That is a signal that your battery is almost dead or drained. If you have the power cord plugged in and the battery is not charging at all, that means the battery is dead and you need to purchase another one.
In windows xp you should be able to click Start/Control Panel/Power Options. When the power options window opens click the Power Meter tab. It will tell you if your battery is charging.
Now to isolate if it's really the battery that's dead or if it's the Power Cord that's bad. You might really be operating on battery power even though you have the power cord plugged in.
1) Turn the laptop off and remove the battery. Turn it back on with only the power cord plugged in. If it comes and and boots up ok, then your power cord is ok.
2) Turn the laptop off and this time put the battery in, but leave the power cord off. Now hit the power button and see if it boots up. If it does that means you might have a little power still left in the battery, but since it was not charging when the power cord was plugged in, the battery is bad because you verified in step one that the power cord is good.
Mar 21, 2012 | Computers & Internet
I have the replacement keyboard for the gateway NV54 laptop. I need basic instructions on removing the old keyboard and unstalling the new keyboard. Can anybody help because Gateway can't help so far.
All them are pretty basically the same. Pull out power cord and battery... Remove the bezel piece top of the keyboard "the thing the power button sits in". When you remove it there should be 2 screws very tiny holding the keyboard down remove them. Under the keyboard there will be the power ribbon DO NOT JUST PULL IT OUT!! There will be like a brown/white clip that locks the ribbon to the board. The brown may be black or even blue that is the locking piece. Carefully lift the clip up and gently pull the ribbon out. If its stuck you have not unlocked it. Pull the old keyboard out and repeat the steps backwards.
Sep 23, 2011 | Gateway NV5468u Notebook
I own a Gateway NV54 computer that operates Windows 7. Recently my computer will only work when plugged in and my battery is not charging.
This is a sign that you need to purchase a new battery. The old one will not hold a charge anymore.
Good Luck
C2Solutions
Feb 17, 2011 | Computers & Internet
My gateway nv54 laptop battery is ok, I've checked it in lap-top tech service. But the system gives me a message "consider replacing your battery" or something like that. With a full-charged...
Unfortunately there isnt much you can do, the only real solution that has ever been known to work is to completely drain the battery (I mean keep trying to turn it on even after its died, many many times) and then put in on charge for 8hrs.
Other than that, regardless of what people say, there isnt much else you can do. And I wouldnt put too much faith in any tests these techs have run, its almost impossible to really see what state the battery cells are in.
For future reference, when you are using your laptop plugged into the mains, take the battery out, that wil help prolong its life, and never let it get too hot or charge it longer than it needs (can bend the cell walls)
Oct 30, 2010 | Gateway Computers & Internet
It is dead no power what can i do
Hi,I believe your shaver is a battery powered model..
If this is the case your Rechargeable batteries (built in) could have been dead..and needs to be replaced.But before taking it to a repair shop ,Whether electric or battery operated model please make sure you check the power cord as well,because sometimes one of the lead cracks at the point that it attaches to shaver,which the power cord needs to be replaced.
If you wish you can describe the problem more details than I may suggest something else.
Regards.
May 15, 2010 | Braun 360° Complete Electric Shaver
Mv acer aspire 3623WXCi turns off when i unplug the power cord with battery attached, is the battery dead and do i need a new one?
when you plug the power cord check and see if the battery shows that its charging ,if the charge level is low allow it to charge fully ,after its fully charged remove the power cord and see if it will go of again .if it goes off then you know the battery is dead if not it might be of low charge or not properly fixed.hope this helps
Sep 17, 2009 | Acer Aspire 3623WXCi (NBACERC1500XX1) PC...
Computer wont come on
well, sounds like your power cord took a dump on you check and make sure power cord light is working first i would suggest
takeing up to office depo or computer store or maybe some one you has a lap like your try the power cord on it and see if it boots up that computer or takea differnt power cord and try reboot it they sale altn. power cords for laptops (cheaper in ebay ,ubid or just type in power cords in your search engine ). i hope this helps lala linda
Jun 03, 2008 | Compaq Presario M2000 Notebook
Gateway Nv54 Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
