Question about Electrical Supplies
Legrand adorne paddle 3 pole switch won't turn on
I purchased a Legrand Adorne Paddle switch for my hallway light. This is a two way light and I installed one of the 2 light switches, but now neither light switches turn the light on. I'm not sure if it matters, but the light is LED. What could be causing the problem?
  • 16,993 Answers
You need to have 2 two way switches in a circuit like that. If you dont have them in each place then it will not work. If you did have a two way in each spot then when you put the new switch in, there is a chance that you wired it wrong. How many wires are in that box that you put the switch in?
Posted on Apr 16, 2014
Testimonial: "The original switch and new switch are 2 way. There are 3 wires in the box. When I disconnected the wires from the original switch, I took the wire that was attached to the black screw (all other screws were brass colored) and put it in the "Hot" section. The other 2 wires I have switched out just in case it made a difference."
Using a Legrand Tru-Universal Paddle dimmer low voltage tape lighting lights pulsating in mid range position of dimming
There is an obvious compatibility issue. Verify the lights are listed to work with that style dimmer.
Oct 20, 2017 | Electrical Supplies
3 Pole light switch won't turn on
Verify your wiring on the switch to make sure that you stripped them to the correct length and that they are fully inserted and tightened down. Also check that you put the correct wire in the correct terminal. The terminal marked HOT will have the either the 120 volt power coming from the breaker or the 120 volt switch leg going to the light fixture, depending on which of your 3-way switches is fed from the breaker. The terminals marked 1-pole and 3-way should have your traveler wires connected to them. Check the switch that you did not replace to see which two wires were used as the travelers, they will be the ones on the screws of the same color. The odd colored screw is the hot or switch leg, depending on which end of the circuit it is on (on the breaker side, it is the hot wire, on the light fixture side of the circuit, it is the switch leg.)
Apr 16, 2014 | Electrical Supplies
I need a wiring diagram for two switches and one light
I f you intend to run one light with two switches you should opt for 3 way switches. the wiring diagram is usually inside the box if you by them boxed.
Mar 08, 2014 | Pass & Seymour / Legrand 1595-2SWT...
I have replaced Decora dimmers with the Adorne dimmers not the lighting is emmiting a high frequency noise in the mid dimming range. The lighting is 20/35 watt halogen lamps. Why and how can I fix this?
They design dimmers for either incondescent lighting or fan motor controls. Always check which one you purchased. You can't use the motor control dimmer on lighting and vice versa. Even if you purchased the correct dimmer remember that it is for incondescent lighting only (ordinary light bulb). Incondescent lights have a resistance whereas fluorescent has a capacitance and an inductance. Halogen lamps may have a capacitance and an induction too and are creating havoc with the mosfet transistor inside the dimmer. This can also cause the dimmer to fail. Read the instructions on the dimmer to see what type of lighting is allowed.
Oct 25, 2013 | Legrand Adorne Control Box with Paddle...
How can i set the on and off of my legrand timer switch
You posted under GE timer, but say you have Legrand, and don't include the model number or type of Legrand timer.
1) The only Legrand timer I have in my files is the RT1 countdown timer
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#RT1
http://waterheatertimer.org/images/RT1-timer.jpg
To set RT1, you push one of the buttons, and fan-or-light turns on for a duration of time, then automatically turns off. Use the large button as ordinary light switch.
2) Legrand also makes commercial line of timers, including din rail timers and pin-type timers
http://www.legrandcommercial.com/control_timers.htm
3) If this is not your timer, add a comment and include in-focus photo of your timer for possible identification.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 26, 2011 | GE 60minute Automatic ShutOff Timer Switch...
I'm looking for a replacement Despard switch that is in a 3 way circuit...but is not a normal 3 way switch. I took it apart and the little spring broke inside so it will not hold position. It seems like...
1) It sounds like you have a DPST 4-way switch being used as 3-way switch.
Look at screws terminals - DPST has 4 screw terminals.
I saw a post that said 4-way despard is no longer made, and couldn't find one either.
2) Next thing is to identify brand, for example Pass and Seymour (Legrand), and then contact that company directly.
http://www.legrand.us/Contact.aspx
Legrand despard switch page:
http://www.legrand.us/Search.aspx?q=Despard%20switch&r=0.07261252740809632
3) Aplus sells P&S 3-way despard switches
http://www.aplussupply.com/ps/switchdevice.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Feb 04, 2011 | Pass & Seymour Acd1cc Despard Single Pole...
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
Electrical Supplies Logo
164 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
