Question about Hitachi Televison & Video
Hdmi ports not working on hiyachi tv - Hitachi Televison & Video
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
Posted on Jan 29, 2009
  • 1738 Answers
SOURCE: HDMI port not working.
If your getting it to work on the regular RCA Jacks then it is your dvr box problem. I would contact your cable provider.
Posted on Dec 29, 2009
  • 8457 Answers
SOURCE: HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
Posted on Jun 28, 2010
How can you tell if the hdmi ports are bad on your tv ( a cable guy said there was bad)
Connect a good HDMI device to the HDMI port on your TV. Make sure the TV HDMI port is selected using your TV remote. Turn ON the HDMI device. If the port is working, the TV and HDMI device will establish a connection and the screen should show some kind of menu display for the device. Regards.
Nov 12, 2015 | Mitsubishi WD Televison & Video
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
How can I connect my TV to a Dell laptop via HDMI?
if oyur LG tv has multiple HDMI ports, then you might need to choose the correct HDMI port from the 'INPUT' menu. Does the HDMI port on TV (sidepanel / back) has a sticker which denotes the number? if yes, then on tv remote, choose INPUT /SOURCE menu, it will show TV, Component, RGB, HDMI1 , HDMI2, HDM3, etc (depending your tv model, these options might vary) and choose the port number which you plugged the HDMI into. if you do not have a number on the port, then you might need to select each HDMI from "INPUT' menu and wait for a couple of seconds.
Sep 01, 2015 | LG Televison & Video
TV won't recognize PC through HDMI port anymore
Thanks for all the background, super detailed! I had a similar problem on a new Samsung that was really flaky with my HDMI from a raspberry pi. Would have to do all kinds of unplugging, cycling power etc like you're doing to get it to work. Once on it would work until I turned the tv off (actually doesn't turn off, but goes to sleep) and back on. Finally figured out that the resolution I was outputting wasn't supported, BUT sometimes it would work. Once I changed the resolution to a supported resolution it worked all the time.
Mar 26, 2014 | Televison & Video
HDMI Ports on Toshiba Flat Screen TV stopped working
That's highly unlikely!!! More likely is that the cable is having problems or that someone mistakenly changed the picture i the TV from HDMI to regular reception. If the HDMI ports are changed to regular TV reception they don't see the HDMI ports only the regular video ports!
Jan 01, 2013 | Televison & Video
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
I have a 37" Insignia L37Q tv with 4 HDMI inputs. Only HDMI 1 works properly. If I hook up an HDMI device to any of the other HDMI ports I get one of the following: 1. No signal 2. Not supported 3....
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 16, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
Jan 27, 2009 | Televison & Video
Open Questions:
Televison & Video Logo
12 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
