Question about Husqvarna Sewing Machines
Feed dogs do not return to up position
I have a 940 model and the feed dogs will drop down, but will not return to up position.
  • 82 Answers
Manually rotate the handwheel a few times after deselecting the feeddog drop. if this doesn't work, take the machine to an authorized Viking for evaluation.
Posted on Mar 01, 2015
  • 29 Answers
SOURCE: feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
Posted on Jul 14, 2007
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
  • 323 Answers
SOURCE: My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
Posted on May 16, 2009
mohammed387
  • 1952 Answers
SOURCE: feed dogs stuck in down position
that the feed dog lever is in the up position. When the lever is in the down position, the feed dogs will show on the top if there is no pressure on them at all. Make sure that the machine makes one complete cycle to check this. Just throwing the switch does not make them come to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
Posted on Aug 26, 2009
How do you raise the feed dog when they're too far down?
Did you drop the feed dogs? If so, if you re-activate the switch, they should come back up when you begin to stitch again. However, if the feed dogs stay in the dropped position, you probably need to take the machine for service.
Jan 19, 2018 | Sewing Machines
Kenmore Sewing Machine Model 385.16221 feed dog is stuck down,m the lever just does nothing. It lowered feed dog, then was useless when I went to raise it to position.
your machine will have a flip type opening at the very front of your machine above the area where the needles are attached to the arm that moves up and down ( it usually has the light globe installed in there ) after opening that door you will see where the dog feed is attached to it should also have a spring that helps the dog feed return to the up position when not in use , make sure it is not stuck in any way and some lubrication oil should be used to prevent it from sticking , while using the dog feed release button push the spring in a up and down motion to help it to dislodge
Oct 28, 2017 | Kenmore Sewing Machines
How to make feed dog rise and fall?
Make certain that the feed dog setting is not dropped as for darning or free motion quilting. Some feed dogs will continue to move forward and backward even when they are in the dropped position.
If that isn't the problem, then you should probably take it for service.
May 20, 2016 | Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
The piece that moves the fabric is down ( as nedded for embroidery) it should be up for conventional sewing, please help me.
look in the operation manual for the feed dog lever and push it to the up position so the feed dogs will come up..
Jun 06, 2015 | Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Model 237 M-A will not feed fabric through.
check the position of the feed lever /knob is not in a centre position
it sets the length of the stitch and if it has moved the feed foot will just move up and down , not back or forward.
May 15, 2015 | Sewing Machines
Sep 20, 2008 | Sewing Machines
Problem with trac feeds
When you drop the feed dogs on most modern machines they do not return to the up position until the motor rotates one full turn. Your feed dog will then be up and ready to use.
Dec 28, 2007 | Sewing Machines
Feed dog is stuck
May 07, 2007 | Singer 2662
Sewing Machines Logo
57 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
