Wash and spin lights on gtup270em1ww are blinking an the washer will not run
4 Suggested Answers
BADBOYJAY
  • 264 Answers
SOURCE: lg washing machine f1068 ldp while washing stopped on spin and all spin lights are blinking
this could be the pump what you need to do is make sure the machine is off and down on the right hand side bottom of the machine there is a round cap clip it down then you should be looking at the pump turn slowly make sure you have a towel down there could be loads or some water coming out DONT undo it quickly OK very slowly until all water is gone then you can pull it out after turning it to pull it out if its all clear then you could have a motor problem but do the pump first OK let me know if this work OK don't for get to put the pump screw back tight OK
Posted on Oct 15, 2012
SOURCE: my washer will spin a little and stop. And the wash light is blinking
We were having the same problem and had a repair tech come out. We were told that we'd need a new basket bearing, but it's only sold with the basket. Also, it could e te complete pump motor assembly. He told us that it would cost over $600. I purchased the complee basket assembly w/bearing for $168.08, through SearsDirect. They sent me the wrong pump, s I'm sending it back. To order the correct one, won't be in stock unil 11/22, so I ordered it from AppliancePartsPros.com or $50.00. Husband is working on it. Level of difficulty is med. skill.
Posted on Oct 22, 2012
  • 222 Answers
SOURCE: A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Posted on Nov 02, 2013
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
Spin light is blinking on my crosley washer
check belt is not Brocken filter is cleaned also can be the motor not turning check brushes or that the motor is not burned
Aug 13, 2014 | Crosley caw9244xq 3.4 cubic foot white...
Gtup270em1ww wont agitate
If you don't have a manual you can download one here and you can buy parts.
GE Laundry Center Parts Model GTUP270EM1WW
Maybe a solution here.
Gtup270em1ww wont agitate YouTube
Jul 01, 2014 | Frigidaire Washing Machines
I am getting an error it is as follows: finished, spin, and wash lights blinking plus 3 beeps. What does this mean?
Try restarting it, make sure the load isnt to heavy, if that does not help, call a local repair man.
Nov 06, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Fills up with water, wont wash, drum motors works
Sounds as if this computer is trying to display an error code. If switching cycles manually makes it work, then it is most likely a bad circuit board. Try doing a google search for "Kenmore washer lights blinking" or something to that effect.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer is Full of water and clothes but won't drain. The washer will not start in any cycle. Lights are on ( the start light is blinking). Tried unplugging but still will not start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
EZ3612 - spins for couple of times then stops with burning smell and mode light blinking 13 times
Per the service manual, if the mode light blinks 13 times, there's a bad dryer sensor or thermostat. I'm not sure if that related to your problem but it's a start.
Doug
Feb 24, 2008 | Equator EZ 3612 CEE Front Load...
Spin speed
If that light is blinking, it's because the spinssense is turned on. If you look at the lighted buttons all the way on the top right of the machine, one of them says spinsense under it. While the machine is running, press and hold that button for 3 seconds. You'll hear a little chime and the light should stop blinking. It's supposed to help vibrations on wood floors.
Oct 16, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
