Question about Home
How do you weave a basket from a palm fronds. My fronds are round fan shaped.
I want to make a nice hawaiian style basket/bowl
2 Suggested Answers
ftcmoa691
  • 5 Answers
SOURCE: I have a frigidaire front
If the top LOOKS like it can open or come off, look all around for any screws that may hold it in place. Then, using a thin, flat, flexible putty knife find the catch release tabs, usually in front, one on each side about 3-4 inches in from right and left front corner. Press these in while applying some upward pressure, use a wooden paint stirrer to apply opening pressure without scratching the paint! If this does not work, DO NOT resort to the Milwaukee Sawzall with a metal blade! The metal shavings will get stuck in your clothing and be very uncomfortable. Good luck!
Posted on May 06, 2011
Where can I find replacement mister nozzles for a Hawaiian Breeze misting fan
They are not available Debbie. What is wrong with the ones in yours? If they are clogged you can clean them with CLR or white vinegar. Or set up a patio misting nozzle in front of it.
Patio misting nozzles are readily available. Your fan is discontinued.
http://www.bing.com/search?q=+Hawaiian+Breeze+misting+fan+nozzles&qs=n&form=QBRE&pq=hawaiian+breeze+misting+fan&sc=0-27&sp=-1&sk=&cvid=EBB007E7ED6D49A6BD8E6A22CCCC31E0
Jul 09, 2016 | Dryers
Why can I pull out brown fronds by my hands on my sago palm's trunk?
Usually once every year or two, Sago Palms bottom frond will die off in order to produce new ones that shoot out the top. Once they die you can pull them out with your hand because the fibers that attach them are also dead.
Jul 07, 2014 | Seeds of Faith Cycas revoluta - "Sago...
My friend mentioned she saw zulu weaved baskets with brightly coloured intricate patterns. is this real? if so, where can i find?
yes, these exist. they are made from plastic-coated wire which is how they get bright designs. can find them here http://www.basketsfromafrica.com/items/zulu-wire-baskets/28077-detail.htm
Feb 27, 2013 | Home
Does face shape actually matter when you are picking a hair style? My daughters all have very different shape faces and I usually just go for matching cuts but I am starting to wonder if it is a bad idea.
You are right in thinking that face shape does play a role in choosing hair styles. Faces can be a whole range of shapes; round, square, oblong etc and different styles with flatter one face shape and potentially look terrible on another. So I would really advise you not to go for a 'one cut fits all' approach with your girls. Ask your hairdresser for some advice. You can even find sites on the internet now that allow you to upload a picture and then muck around with different hair styles so you can see how they would look on you.
Feb 14, 2013 | Health & Beauty
I have a very round shaped face no matter how much weight I lose. What kind of hair style will suit me best?
If you have a round shaped face, you need a hairstyle that will lengthen your face rather than emphasize the roundness of it. If you have layers, put them at the top to add height but thinned out under the cheekbone line to give the impression of a narrower chin.
Jan 10, 2013 | Health & Beauty
Hi there, we have recently moved house, the palm tree (according to the previous owners has been there over 16 years planted by themselves). The tree has been shedding its leaves over the winter months,...
Hello Eileen, W/D here.
Palms will reabsorb some of their nutrients when fronds are shed, even over winter. If possible, you should let the ugly fronds go, and allow the trunk to take back what's stored in the frond stems. When they become brown, or less green, or droop, they can be pruned. This is usually found with the lower fronds. If upper fronds exhibit these symptoms, it is usually from the effects of winter, but the same rules apply, except that you can trim partial fronds to get rid of the brown leaves.
The acid test for a palm is, if there are shoots in the middle of the canopy protruding, to pull on them firmly, but not aggressively. If the shoots pull out easily, the palm is probably dead. Some winters are more brutal than others, and palms take the worst of them. We double-cover our palms, and place lights inside of the covering that we make, and the larger ones have made it over winter now for about 5 years. I have used incandescent Christmas lights wrapped around the trunk and hung in the canopies, then covered and it worked well too. One friend slaved his Christmas lights to his pool pump control panel, only to lose his palms. Seems that he was using LED lights, which put out no heat. Queen palms have died in droves this, and last year, as have unprotected Robellinis. Washingtonians and Pindos have fared better. If you live in a coastal zone, you still need to cover and keep your palms warm through the worst of winter. We have used fitted sheets on the smaller canopies to contain the fronds, then covered that with plastic tarps, weighted down on the sides to form a mini greenhouse, and it works pretty well, but it's inconvenient. With spring here, there will be a lot of new outdoor umbrellas purchased, and the old ones will be pitched. We already have picked one up from a neighbor, and will erect it over one of the palms, then cover it as described. The thinking here that it should be much easier (and quicker) to protect the palms via this method.
As for the fungus noted, try light applications of a fungicide, but check first with a local nurseryman to see what works best in your area.
Hope that this is of some help.
Best regards, (and please rate this solution), --W/D--
Apr 02, 2011 | Sport & Outdoor - Others
How could I know which sunglass suites me?
Well, here are some advices on how to match your sunglass to your face: 1. Suare face: Most complimentary style of sunglasses for a square face: To minimize the width of the face, it is best to choose sunglasses that add length. This can be best achieved by buying sunglasses that are not as wide as the widest part of your face. It is also a good idea to soften the "squareness" of a face by more fluid, rounded style frames, so as to decrease the perception of a broad jaw line. 2.Oval face-Most complimentary style of sunglasses for an oval shaped face: Generally any type of sunglasses suits an oval face, but just make sure that the size of the frame is proportionate to the face. 3.Round face: Most complimentary style of sunglasses for round shaped face: To sharpen a round face, select frames with straight or angular lines that will help make the face look thinner and longer.
4.Diamond face:Most complimentary style of sunglasses for a diamond shape face: Glasses that are oval, shaped or rimless are very complimentary for this type of face.
5. Rectagle face-Most complimentary style of sunglasses for squar shaped face: To compliment this style of face, it is best to choose sunglasses that will shorten the face and widen the face, both at the same time. The best style of frame to choose is one that is round, or deep to help soften the face.
6.Triangle face-Most complimentary style of sunglasses for a Base-Down Triangle face: To compliment this style of face, it is best to emphasis the top part of your face with strong balancing frames. 7.Inverted triangle-Most complimentary style of sunglasses for an inverted triangle face: Choose a type of frame that balances your face and broadens the lower part of your face. Low temples and rimless style of sunglasses are a good style to consider.
Nov 07, 2010 | Clothing Accessories
Need a replacement bowl for my Kenwood Chef
I have an Excel that has the D shaped bowl but the base of it is round. Since the Excel does have a round base you can fit any existing bowl onto the Kenwood including their newer stainless steel bowl.
Mar 13, 2009 | Food Processors
Home Logo
435 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
