Sony bravia problems....intermittent fault. Colour turns psychedelic. Looks like TV is "on acid"!! Sometimes TV can run normally for several hours before the colour fault occurs.
TV can sometimes run for several hours before colour turns psychedelic. Looks like TV is "on acid"! Other days fault is there from switch on. Is this an expensive fault?
    Scholar:
  • 101 Answers
You have a defective T-Con board. The small board near the top center of tv. Can not give you the part number without knowing your TV model. Depending on model $50-120 for part.
Posted on May 06, 2014
SOURCE: audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Posted on Jan 15, 2008
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Posted on Jun 13, 2009
  • 3 Answers
SOURCE: my sony bravia digital channels always drop out of
For tuner problems, especially the digital channels, you should check for a TV firmware update at www.sonystyle.com. I was having some strange loss of digital channels on our 40" Bravia, starting with channels only appearing for a second before the screen produced a 'No Signal' message. After we tried the automatic retuning, then we could not even get the one second signal. None of this appeared on the description of the download. However, we downloaded the patch to our PC, loaded the file (19 MB) onto a small flash drive, which we then used to upgrade the firmware in the TV. All our digital tuner problems disappeared!!
Posted on Nov 28, 2009
SOURCE: 40" Sony Bravia has intermittent audio failure.
I have a KDL-46VL130 with the same problems. Audio on the HDMI connection turns on and off intermittently when I have it connected with my ATT Uverse rcvr. I check w/ Sony online support and they led through the standard troubleshooting process ... which I knew going in would not fix the problem. Ultimately they told me to try a new HDMI cable first, or try a different video source for the HDMI, other than my ATT U-Verse reciever and see if the problem persists. Having seen other articles on this issue, i am almost certain that is not going to fix the problem... and to think that I paid $2000 for this thing.
Posted on Jan 25, 2010
I have intermittent horizontal lines covering the whole screen. Sometimes it flickers and sometimes the lines are ghost images. When the lines are black they tend to be thickest at the right and almost...
That's a problem. If it's still in warranty you're in luck. Either take it back to the store, or call Sony to have it repaired under warranty. If it's out of warranty they can send a third party servicer to your home to the tune of $400 labor (in 2008) plus parts in the US. I will say this much, if it turns out to be an LCD panel issue, the panel will cost about the same as the TV itself when it was new.
The issue you describe sounds like the scan frequency isn't right for the video you are watching. In other words, it should be 720P and it is running at 1080P instead, and you wind up with a horizontal fold-over type of line.
That makes that new OLED TV a little more enticing!
May 21, 2016 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
I am getting black colour is shaded and looks as silver
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 11, 2015 | Sony Bravia KDL-32V4000 32 in. LCD TV
What colour connecting cable from camera to tv
Normally and standard, it's the yellow head cable. But sometimes if the yellow one doesn't work. Then try others. This won't hurt your TV or the camera.
Hope this helps
Sep 25, 2014 | Sony Cyber-Shot DSC-P10 Digital Camera
Im not too sure on the serial number of my sony trinitron but iv gone off what looks most like mine! the problem i have is that the four corners of my tv set have changed colour when i turned it on at...
Hello
Your TV has degaussing problem I thinks. There is a coil fitted around the screen, through which an AC supply is fed each time when you switch on the set, and it will last only for about 3 microseconds or so, to demagnatize your picture tube. In specific timing is accieved by the help of a "Posistor" usually called as degassing posistor. If it fails to work, the fault you have mentioned will occur. If you turn your TV in an other direction, say if it is paced east-west, turn it to south-north, the colour change now you see will be in an other state.
You just open your TV. The said posistor can be located on the power section of your TV. It will be normally black in color, looks very like a small chocolate. There are two types of posistors are used by Sony. One type has only two connections, and the other have three. You just replace it, it is very easy job. Just desolder it out, and go for a same type of posistor. It is quite normal fault in all TVs. OK.
Nov 12, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Jun 13, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Feb 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
May 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
