Question about Yard Man Garden
HOW DO I REPLACE BELTS AFTER THEY CAME OFF?
MODLE MODLE #13A0771N0551680549 3
    Guru:
  • 145 Answers
After a belt has fallen off it will need to be replaced. belts usually just don't fall off. WITH THE ENGINE TURNED OFF! belt removed check the pulleyes and idlers a possible bearing failure or maybe a quill (the blade mounting tower) has a broken mounting point. A good website for ya mtdparts.com
Posted on Apr 19, 2014
My Bissell 61c5-g started making a loud noise, vibrates bad, what can I check? I adjusted the height and it isn't connected there.
Most likely a bad belt. Contact Consumer Care at 1-800-237-7691 to order parts (detailed instructions comes in the package. To open the Belt area access panel you will need a flat medium sized screwdriver. There are two slots on the right hand side of the unit. Push the screwdriver into the lower slot and press the holding tab to lift the panel. The top tab should slide out easier but if it doesn't use the same process as the lower one. Examine the belts by rotating them all the way around (there may be two belts in your unit). I'd recommend if one belt is bad to replace both belts and keep the used one as a spare. Good luck. Hope that helped.
Oct 30, 2015 | Bissell Vacuums
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
I can't find my modle #--My modle is HD52W67- but
Replace the Flyback number 270125 and CP150 they are both available at the following link and they provide step by step instructions.
http://servicemanuals.vstore.ca
Jun 09, 2011 | RCA HD52W59 HDTV Projection Television
How often should you get engine belts replaced and what belts need to be replaced?
Replace belts as needed, check for cracks on the sides of the belts or pieces missing from belt. A good belt should last 100,000 miles. and it is a good practice to replace at 100,000 even if it looks good. REPLACE ALL BELTS as needed.
Jan 18, 2010 | 1996 Nissan Pickup
Our flat samsung 40 inch just clinks won;t come on
REPLACE 3 -4 CAPACITORS IN THE POWER SUPPLY, THEY ARE SWOLLEN UP OR LEAKY
Dec 30, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
99 escort zx2 timing belt
Advance auto parts or just about any parts store that carries Haynes manuals can fix you up for about 15 bucks. Lee
Please vote if this was helpful or not
Oct 12, 2009 | 1999 Ford Escort
Faded color on 27" GE Modle#25GT270
Considering the age of that GE model I would suspect the CRT is showing signs of weakening. Time to replace the TV...
Aug 31, 2009 | GE 25GT270 TV
Dyson washing machine memory modle
open both doors, on inside of inner door are 2 brass screws,
remove these and pull handle off,
to replace just squeeze locking mechanism through same hole and replace 2 screws .easy.
May 16, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Garden Logo
48 people viewed this question
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
