Question about Zebra Audio Players & Recorders
The problem is i can't find a freaking phone number to order a replacement part for this zmc-110 speaker that doesn't work.............
I have a Technics SU-G70 Amplifier with a problem. Overall, it works fine except for a speaker issue. When turned on, the Left speaker output on the monitor is lit up from 0 to 120. Just below, the...
Sir the problem of your unit is the power IC the other channel of this IC is already faulty. unplug the unit to the main AC outlet then remove the cover of your unit you will see a large aluminum plate the power IC is attach to that heat sink in order to fix this you should replace the IC. Or can you give me the part number of the IC so I can determine the pin configuration. Good day and best regards.
Sep 15, 2011 | Technics Audio Players & Recorders
I have lost my power cord to my t500 speakers how and where can I get an replacement
I would just call cambridge sound works and order another one! go to cambridgesoundworks.com and look for the phone number. you should be able to just get one from them!
Aug 21, 2011 | Cambridge Soundworks Newton Series T500...
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Actually water went inside the phone and the speaker is nor working
If this was a recent accident, place your phone in a plastic bag full of rice and let sit for a day or two, this should get the water out of it, If that doesn't solve issue or the water entered the phone a while ago, your phone probably needs to have the speaker replaced
Jul 02, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My media and ringer sound doesn't work but my in-call sound works and the volume is all the way up.
you probably have an external speaker on the phone separate from the earpiece you will probably need to have the external speaker replaced on the phone...the speaker is usually in the back piece of the phone... hope this helps
May 16, 2011 | Cell Phones
My Samsung Seek Wont Receive Texts , From Other Numbers , But I Received One From A Sprint Holder
Ensure you have off network texts enabled by reaching Sprint. Sometimes they turn them off if you don't have texting on the phone in order to save you money
If this doesn't work you may want to talk to Sprint about replacing your phone
May 16, 2011 | Samsung Cell Phones
I HAVE A CLARK 110 VOLT MIG WELDER IT IS THE 130EN.THE NUMBER 4 POWER SETTING DONT WORK BUT ALL THE OTHER 3 DO WHAT COULD BE WRONG
Tear it down JUST far enough to gain access to the switch,check for and correct :corrosion,rust,oil or grease buildup,and/or damaged contact(s) at that station. That doesn't work,replace the switching unit.
Apr 28, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Need replacement balls for Busy Ball Popper
Hi, I purchase from amazon last time for my kid. here: New 1st Steps Collection by Shakira Fisher Price. You can find them for 4.5$ and above... I hope I have helped. cheers
Mar 26, 2009 | Playskool Busy Ball Popper
Cobra radar detector speaker replacement
I called cobra support(777-889-3087) and it was around $6 plus shipping for a replacement speaker.
the correct phone number for cobra support is 773-889-3087 and can be found on their website.
Cobra was very courtious and I also got my replacement speaker for my XRS-9500.!
Feb 20, 2008 | XRS-757 Radar Detector
47 people viewed this question
Top Zebra Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Zebra Audio Player and Recorder Expert? Answer questions, earn points and help others
