Question about GE JE1860 Microwave Oven
No turntable I refuse to buy a new microwave until they get rid of the turntable design. I need my casserole dish to fit! My old GE is 11 years old and going strong. Perhaps a US company will see the need for a microwave with no turntable and make a LOT of money, taking market share away from other countries.
    Problem Solver:
  • 8 Answers
I fixed the problem with my microwave turntable motor without having to replace it. I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate. Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ?bumps? on the underside of the gear on top and washer on the bottom. Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place. If this worked for you please let me know ? karlet@bellsouth.net
Posted on Aug 21, 2009
I have a ge model JVM1850. It is 6yrs old. Today it suddenly did not heat a frozen small item thru. Does this sound repairable or do I need to consider replacement? It is above oven.
well!!!!!! its 6 years old,,,,my bet is the manatron has failed,,,and thats a pricy part to buy and have fitted,,,
you may find in the long run its cheeper to just buy a new microwave,,at least it would be a new one and not 6 years old! and not a patch up job
Jun 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Which microwave has no turntable?
look at the features the new microwaves have. alot of them have a button to turn the turn table off
Jan 31, 2009 | Microwave Ovens
My turntable stopped running
If you didn't buy the turntable motor then I assume you purchased the coupler ( white plastic/nylon piece that fits into the turntable motor collar and rotates the platen? Is that what you purchased?
Sep 13, 2008 | GE JES1384SF Microwave Oven
I own a Advantium 120 Oven. I love my microwave however there are times that I need to stop the turntable in order to reheat or cook something in a casserole dish. How can the turntable be turned off?
I guess my problem cannot be fixed. I was told that my microwave turntable is automatic and cannot be turned off, therefore, if you have a 9 1/2 x 11 dish and need to reheat something it cannot go in the microwave because it does not fit .
Aug 26, 2008 | Microwave Ovens
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE JE1860 Microwave Oven Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
