Question about Danby DPAC9030 Air Conditioner
Connecting a hose to take out condensation Danby dpac7008
There is a containeer that fills with water and when it is filled it automatically shuts off the unit. I was told you can set up a water holes and run it to an external drain, but the hose that is connected to the unit gets smashed when I pull it out. In order for the unit to start again the container haas to be replaced and there is no room for the hose to come out without being smashed causing the water to fill the container and shut off..
  • peartgallery Jun 18, 2009
    I have misplaced the manual, but I'm quite sure it said that I could hook up a hose to it without taking anything apart.
    Sergeant:
  • 340 Answers
You'll have to take it apart their is a switch which will have to be by passed .hook up your hose to a drain good luck . Tom
Posted on Jun 18, 2009
My portable ac says to add water, how do i do that
There are 2 issues.
The first is that there is a water container in which you must fill water so the compressor cools. This is housed usually in the side. There is an automatic push panel on the side of the unit which when pushed opens the door. The container sits inside which needs to be taken out and filled daily.
The other is the water that condenses because of cooling the air. This settleas at the bottom of the ac. Bend down abd you will see a drain plug and a rubber blocker. Unscrew the drain plug and pull the rubber. All the condensed water will flow out. It can be messay so preferably drain in the bathroom.
Nov 15, 2011 | Soleus KY-34 Portable Air Conditioner
My Danby DPAC1010 Portable Air Conditioner is dehumidifying when simply in AC mode. I don't want it to, but if fills up a 2 gallon bucket every 2-3 days. I've had it overflow twice and I cannot...
The only way to stop it from dehumidifying is to stop it. A dehumidifier is a AC that is 'tuned poorly'. In your machine, while in dehumidify mode, you actually are running the AC in 'slow".
It is a law of physics. Warm air can hold moisture. Cold air can not hold moisture. When you remove the heat from the air, the water has to go somewhere, so it condenses on the coils and drips into the tank. Yes, that is true: Heat is a thing, you have to remove heat from the air. You don't simply "cool it", you remove the heat.
Your Danby should have a automatic shut off that comes into play when the condensate tank gets full. MY Danby, which is a sllightly different model than yours, has a connection that allows me to connect a hose that I lead to a floor drain to disponse of the condensate (water).
If yours is not equipped with a shut off nor a drain and you say it fills every 2 to 3 days, the options I see that you have is to dump it every day, or - don't run it all the time, or - turn the setting to a higher number which will reduce the AC and dehumidifying effect. On the down side of that, your humidity will remain high at the higher setting.
Thanks for your question @ FixYa.com and thanks for letting me assist you this evening.
Jun 29, 2011 | Heating & Cooling
My Danby 5070 is leaking water eventhough the resevoir is not filled. My carpet is soaked and the water is a rusty colored. Suggestions?
This probably means the condensation pan is rusted out and the condensation is dripping through the bottom of the pan. The pan will have to be replaced. Sorry this is probably not just real good news to hear. Hope this helps is some way.
Jun 22, 2011 | Danby Heating & Cooling
I just recently purchased an air conditioner and I need some help with the installation. In the booklet it says that if you want continuous drainage that you need to have the continuous drainage hose out...
The model you have has an evaporator feature, that normally evaporates the left over condensation. However, there are times that the humidity level may be to high to handle all of the left over condensation. In which case, the pan would need to be drained. In most instances, a plastic low sided container would suffice. But, if you run the AC unit in a continual mode, there's a good chance not all the left over condensation would be evaporated.That's what the hose is for. Not sure why there are 2 of them. Generally there's only one. Anyway, the unit also will shut down automatically, if the pan gets full and needs to be emptied. It will not run until it's emptied. But, I caution you not always rely on that. Anything can go wrong when you're not at home.
Hope this helped you understand how the unit operates. If you have any more questions, call Danby's Customer Support Dept. The 800 number is in your Owner's Manual. They're good folks and will do what's necessary to help you.
Jun 16, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
Aug 31, 2009 | Danby DDR6588EE Dehumidifier
Water tank fills up every 3hrs
The amount of water that is getting extracted from the air in the room is based on how humid the air is. The good news is your unit is really getting quite a bit of moisture out of the air and as such, is working well to cool your room.
It is working as designed. You may want to see if you can connect a hose to a drain port (if yours has that included) to let the unit room longer without the need to drain the condensate (water) every 3 or so hours.
Hope this helps and best regards!
Jul 31, 2009 | Danby DPAC8020 Air Conditioner
Danby dpac120068 Air Condtioner, where does the hose go? and do you fill the tank in the back with water?
hose goes into a bucket or out a window, drained, etc. it's the drain hose for the condensation. alternatively you can use the tank to catch the condensation, which must be emptied periodically.
Jun 14, 2009 | Danby Portable Air Conditioner
Water tank is suddenly filling up
look closely how the water flows from the evaporator to the tank. does it goes first to the condenser ?..or is there a heating pipe that is touching the tank in order to heat the water for it to evaporate?
here's the set up, your ac would cool and absorb moisture in the air and becomes water in the evaporator. these water is sometimes used to cool the compressor or the condenser to help it run cooler and at the same time evaporates the un-needed water . but incase the water is so much then you have the tank to keep the water from spilling. sometimes they still put some hot pipes to further heat the water to evaporate.
check those pointers that i have mention.
in some case, the air in your place just got humid and wet that is why it has too many water condensation..
Aug 08, 2008 | Danby DPAC8099 Air Conditioner
Drainage bypass to hose not working
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Oct 05, 2007 | Maytag M3DH30B2A Dehumidifier
Open Questions:
See all Danby DPAC9030 Air Conditioner Questions
Danby DPAC9030 Air Conditioner Logo
412 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
