Question about Sonance Sonamp 260 MKII 2-Channel Amplifier
I can switch the unit on but there appears to be no out to any of the speakers in the house
    Master:
  • 371 Answers
Probably needs output relay
Posted on May 02, 2015
    Problem Solver:
  • 62 Answers
Follow the wiring.
Posted on Apr 23, 2014
Appears to have blown speaker. How does unit come apart, tried prying on front no luck don't want to break unit. Are there screws anywhere to remove?
There may be screws on the bottom, under the rubber feet. The faceplate may come off with screws under them.
It's also likely you have a bad connection or bad amp rather than a bad driver, unless you've been connecting your speakers to an external amp that's too powerful, and playing loud, If that's the case, you will likely be looking at new speakers.
Oct 14, 2015 | Audio Players & Recorders
I dont have any sound one min. it played the next it didnt
hi paulamreel, before tossing the unit check out the speaker wiring and condition of your speakers. if any of the eight speaker lines is shorting or touching the body(ground) of the vehicle, your problem will persist. if one or more of your speakers is faulty(check tweeters and midranges too) then this condition will persist. if the fault only appears while listening to the radio section and your unit has a rds feature then try switching off the TA feature for better reception. its all worth a try. cheers!
May 24, 2012 | Pioneer DEH-P8600MP CD Player
"PROTECT" appears on my DENON DHT-500SD
Sounds like a speaker wire is shorting against either another speaker wire or something metallic. Check your speaker wires to make sure they're not shorting (touching). If that doesn't work, I'd take it to a repair facility. Good luck!
Feb 16, 2010 | Denon DHT500SD System
Boston Acoustics VR960 Crackle
I just finished repairing one of my VR960 units with a similar problem. My problem was that the sub would crackle no matter what input level. After changing a few of the active components, I finally discovered it to be a capacitor which was faulty. Anyway, I replaced the three 100uf 25V capacitors on the main board and all was well.
Good Luck.
Jul 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Humming noise
You have a failed capacitor on the power board
Mar 28, 2017 | Logitech Z-3e Computer Speakers
No home theater sound
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 07, 2009 | Denon AVR-4800 Receiver
Sound issue
It is not necessasry to change the kit all time.
Check whether this unit has been upgraded before or not.If this unit upgraded before you dont need to change Kit.
May be problem with Y-sus or Z-sus boards.
Good luck
Dals123
Sep 25, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Panasonic stereo SA-PM28 displays fault code F61 then switches off
Hi dearnley1
The error code your unit is presenting relates to either a speaker cabling fault or a fault speaker. Sometimes, it is neither, and may be a fault inside the unit. Needless to say the unit is in protection moe to prevent more damage occurring. Check you speaker wiring for any short circuits or frayed wires. If all appears to be ok, disconnect the wires from the unit and see if it turns on and stays on then. If it still presents f61 with speakers and cable disconnected, then I am afraid that you may need to take the unit to a Kenwood service center near to you for an inspection . Good luck
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
NAD T753 5.1 Channels Receiver Problem
It could be a heat issue, is the receiver able to get air to cool itself? Also, a bad speaker or mismatched speaker may cause this. Sometimes hooking up extra speakers may cause this. Other than that, it would be a service issue.
Geno
Mar 05, 2008 | NAD T753 Receiver
Sonance Sonamp 260 MKII 2-Channel Amplifier Logo
192 people viewed this question
Top Sonance Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ASTEREY ELECTRONIC...
Level 1 Expert
Are you a Sonance Audio Player and Recorder Expert? Answer questions, earn points and help others
