Question about Nikon D70 Digital Camera with 18-50mm Lens
DSLR - Camera stuck in formatting mode
Have a Nikon D70. Tried to format a 4G SD CF Ultra II. Would not complete formatting process. 4G card tried in Canon SD500 and worked fine.
Switched back to 512 SD CF that had been previously formatted for the D70. Shot images until card was full. Uploded images to PC and erased card. Placed 512 back into D70. Camera is now stuck in formatting mode. Have removed battery, tried other previously formatted SD CF cards and cannot get the D70 to work - stays stuck in format mode ("For" flashes where number of images should appear).
  • TiggerandMoo Nov 03, 2007
    Please explain in greater detail. Menu in camera will not allow me to format the disc.
  • TiggerandMoo Nov 08, 2007
    First reply did not fix my problem. Anyone else out there that can help?
  • 4,102 Answers
Can you plug cam strait into comp if you can you will need to reinstall the software for the camera you should have got this when you brought reinstall this software this should solve your problem hope this is some help............................................
Posted on Nov 08, 2007
  • 790 Answers
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Posted on Nov 02, 2007
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.-
Mar 28, 2017 | Computers & Internet
My NIKON D70 has trouble with flash cards larger than 2 G.
The D70 has known issues with certain cards / capacities. Nikon has identified the cards and capacities that are guaranteed to work with the D70 specifically, on their page dedicated to this info linked below:
It seems that only Lexar and Microdrive cards that are 4Gb are supported (some with significant limitations) and no card greater than 4Gb is supported at all, regardless of manufacturer.
Oct 10, 2009 | Nikon D70s Digital Camera
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
Jan 30, 2009 | Nikon D70s Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Nikon d70 firmware version 2.0
u have card reader stick sd card in that formatt to fat 16 ok for cam if it had hd video use ntfc formatt ok
Feb 02, 2008 | Nikon D70s Digital Camera
Camera read CF card, but cannot see on USB or other media
You can connect the camera to the computer via a USB cable and use the camera as the card reader. It will show up as a mass storage device. You should then be able to copy the images to your PC and format the card once recovered.
Sep 17, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Hm, odd problem, I'd try reformatting the drive (Windows) My computer > Right click > Format. If the drive's corrupted, that could be causing your problem. But remember, formatting will erase ALL data on the drive, back it up before you try this.
Aug 22, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Memory Quit working
Hi there, please check with the Nikon Dealer the 4G card compatibility issue, maybe the card is too big for your camera. Best regards, Arpi
Jun 17, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
200 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
