Question about Garmin GPS 12 GPS Receiver
MY GARMIN GPS-12 TURNS ON FOR 2 SEC THEN SHUTS OFF
SOURCE: Garmin GPS 12 suddenly turns off
Use the paper, It worked for mine. I almost tossed it but now it's fine.
Posted on Mar 05, 2008
  • 59 Answers
SOURCE: garmin gps 12 wont turn on.
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
Posted on Apr 25, 2009
  • 10 Answers
SOURCE: My Garmin GPS 12 Turns Black On turning on.
Try turning the unit on and hold the left arrow button down for about 10 seconds.
Posted on May 12, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a garmin gps 12--s/n 35854358. No auto-locate?
If you haven't used the gps for a while they can try to operate with the incorrect catalog or time. Unless these are both correct it gets lost. Usually you can correct this with a forced reset. There is also a update for this unit which also forces the update.
http://www8.garmin.com/products/gps12/download.html
The data cable sort of screws on and makes contact with 4 pins. This is the little round connector. It does both power and data. The cable is a wee bit pricey from Garmin but you can make them or just get one from ebay.
The reset usually wipes out any saved routes poi's etc so using the data cable will save all of those. To reset the 12 I believe you hold the lower right corner of the screen and then power it on to reset. Then you need to let it rub until it gets the new data which can take 5-50 minutes. Makes sure your batteries are good.
I'd recommend the data cable route (use a 'gasp' non garmin cheap cable) and upload the update at the same time and you should be good to go try and get lost again.
Posted on Jun 28, 2010
guru_fixya
  • 944 Answers
SOURCE: turn on my garmin, starts
This problem occurs due to two reason.
1)corrupted firmware.Just reset it.
The reset button is very hard to see. It is to the right of the serial number, hidden under the plastic membrane and labeled in subdued print. I had to use a flashlight to find it. Just use a pointed object like a pen to press down on the printed square while holding the power switch to the right. My unit came back on after a few seconds.
2)Change the battery.It is inside it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 25, 2011
My c340 garmin only turns on for about one second then shuts down
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Apr 30, 2010 | Garmin StreetPilot c340 GPS Receiver
Nuvi 360 turns off randomly with 1 battery bar
Have you tried updating it from Garmins site?
Mar 25, 2010 | Garmin Nuvi 660 GPS Receiver
When i turn my gps on it stays on for only a few secs whether its plugged into its power source or not.....whats the problem
i turn it on and it stays on for like 2 sec and then it turns off on me or when im putting a route in then it goes and durring the middle it turns off on me.
Nov 28, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin turns on and shuts its self off.
But it might have a very low charge or a bad battery (despite being connected to Dc) recharge the battery from AC or replace the battery
Jul 24, 2009 | Garmin nuvi 255W GPS Receiver
5yr old Garmin 76s shuts off
KUDOS! Others with the same problem informed me that it is a softwear problem and to download the 4.0 version free on the Garmin web site....l'll do it ASAP and write again if it doesn't work...RG
Jul 19, 2009 | Garmin GPSMAP 76 GPS Receiver
Garmin 178C Stays on for 20 secs then turns off
I had the same problem. In your settings you can set this thing to monitor your battery's power so it auto shut down if your battery goes below 11.2 volts or so. I disabled this and it has worked ever since.
Jun 16, 2009 | Garmin GPSMAP 178C Sounder GPS Receiver
Apr 01, 2009 | Garmin GPS 12 GPS Receiver
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin GPS 12
ok
inter in the site garmin
support+updates downloald+additionnel software+gps12+
ther is 2 version 4.60 dowload+ upleod
NB you must connect GPS and BC by cable
goodluck
from redbel001@hotmail.com
Dec 12, 2007 | Garmin GPS 12 GPS Receiver
Stay clear of rechargeable NiCads as they supply to low voltage and you may experience cutouts ? Use good quality regular alkaline batteries. Check battery terminals in gps (both ends) for corrosion/rust and clean if necessary.
Dec 10, 2007 | Garmin GPS 12 GPS Receiver
Garmin GPS 12 GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
