Door open wont washer
Door to Amana front load washer stuck in locked and delayed position
    Scholar:
  • 126 Answers
Possibly some foreign object has worked it's way down into the drain pump, preventing the washer from draining. all the way. (If the washer doesn't drain properly, the door will remain locked).
One way is to take the drain hose out of the wall connection, lower it to floor level & allow it to gravity drain. (Be sure to catch the water in a pan or something). Once the washer has drained, the lid should open.
If this fixed the problem, the pump still has something in it. You will need to remove the back of the washer and check to see what's blocking the discharge pump.
Remove the back of the washer, remove the hose running to the drain pump, remove the pump itself & remove and debris clogging the pump.
Otherwise a service call runs somewhere between $100 - $175.
Posted on Apr 16, 2014
  • 3 Answers
SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
Posted on Jun 08, 2008
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
SOURCE: my front load washer has the door lock stuck and
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
Posted on Feb 22, 2010
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
SOURCE: door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
Posted on Dec 19, 2010
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
Mar 06, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
WHIRLPOOL FRONT LOAD DOOR LOCK IS STUCK IN
try pushing in the door at the same time as you try to unlock it?
you could try giving the side of the washer a good hard slap? that some times jolts it into working,, but at the end of the day its a repair mans job to sort it out unless you realy wont to take the top off and pull on the cable to unlock the door>
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door wont lock
I solved my own problem...
The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
Mar 28, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Amana front load washer door locked with door open
Feb 25, 2009 | Amana Washing Machines
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
