Question about Cateye Fitness Cycling
Body fit kh9859
Is there an instruction manual which covers how this bike computer works?
3 Suggested Answers
SOURCE: Schwinn women's 26" Windwood front fender doesn't fit correctly.
You have it on backwards.  I had the exact same problem.  Turn the fender around so that the arms that connect to the axel are pointing forward.  They are going to be almost parallel to the ground.  Easy Peasy lemon Squeezy.
Posted on Mar 28, 2009
murf427
  • 336 Answers
SOURCE: vital-fitness-recumbent-bike instruction manual
Go to support on their website and you'll find an owners manual. murf427
Posted on Aug 30, 2012
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
Exercise bike instruction manual
WARNING Do not attempt to open the back cover of the Monitor console. This is not a battery storage area; this Computer is powered by an AC Adapter. This bike is to be used only indoors and in a dry location. Do not plug the AC Adapter into the wall until the electronics monitor is completely assembled.
Jul 16, 2014 | Fitness Quest Edge 482U Upright Exercise...
Have a stairmaster recumbant bike which has generally worked well. Recently however had problems. Start pedalling to activate control panel, input data such as weight, level and time, however as soon as...
If the bike is working with Battery, Replace with alkaline batteries, and clean very well the spring with special electronic cleaner contacts, you can buy in any electronic stores.
2) Tight the connector well, and clean with cleaner contacts.
3) See if the small motor inside is working good, or the wires is faulty , and repair or replace.
LUBE very well the bike, follow the instruction manual steps.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How to Lubricate an Elliptical Fitness Exercise Equipment
Nov 12, 2017 | Stairmaster 3800RC Recumbent Exercise Bike
Is it true that number of ways exist in order to choose the right bike size?
There is no "one true way" to decide proper bike fit. Actually there are hundreds of methods, tables, charts, computer programs, and cycling gurus, each of which claims to have the best way to determine what bike size and setup best fits you. Part of this confusion is because most ideas about proper bike fit come from experience or tradition, not scientific study. What scientific study there is on the topic, usually looks at what makes a rider fast and efficient, not necessarily comfortable. Most of the tradition and most of the scientific study comes from the bike racing community, not average recreational riders. And that's the underlying problem: riding a bike is a compromise, just like everything else in life. What makes you more comfortable on the bike mostly makes you slower. What makes you faster on the bike usually makes you less comfortable. So "proper bike fit" depends partly on your choice on that question. Do you want to go faster, or do you want to be more comfortable?
Many experienced bike riders might read those last few sentences and scoff. All their cycling heroes ride with backs perfectly flat, arms stretched out, handlebars much lower than their saddles, on very small frames. Surely this can't be uncomfortable, they ride almost every day of the year, usually several hours at a time?
It's true, these professional racers are reasonably comfortable riding in that position. But they are professional athletes, paid to be fast and get results, not to be comfortable. Their bodies have adapted to this position because they do ride several hours a day, every day, year-round. Their upper bodies don't suffer as much because their legs are pushing hard all the time, which takes weight off their arms even when quite bent over. Their body type is suited to it-very little body fat. And to put it simply, they put up with some discomfort to go faster. It is fine to look up to bike racers, but their bike fit and riding position is an unfortunate model for the rest of us to try to copy.
Dec 21, 2010 | Cycling
2002 1150 rt will not idle without choke on ,even after say 5 minutes and oil temperature is reading 5bars
Hi, your problem could be either fuel or an air leak. I would sugest you aproach this problem in a systematic way. Have you performed any adjustments or maintenance on your motorcycle prior to this fault occuring?
Possible causes, cylinders are not receiving the same amount of fuel/air, ie they are out of ballance and one is fighting against the other. To check this requires a fair amount of work on this bike plus access to a set of carb balances.
I would suggest to start you remove the clothing on both sides of the bike to gain access to the throttle bodies, when this far check underneath the throttle bodies that the rubber plugs are present covering the small brass stubs and that they are not split, this is where I would suspect an air leak to be, if all ok here and you have aquired the carb balances then perform the test and adjustment as per instructions for the kit.
The other cause could be fuel starvation, have you had the petrol tank off or disturbed it at all? It is very easy on these bikes to trap a fuel line under the tank when re-fitting !
Dec 12, 2010 | 2002 BMW R 1150 RT (ABS)
Mar 15, 2009 | Schwinn Windwood 26 Women s Cruiser...
My new reebok i bike has arrived without asembly instructions
http://www.reebokfitness.co.uk/index.php?id=3&L=2
The above links to the reebok website where they have pdf copies of all manuals for their exercise bikes and computer parts - ibike and its computer is there.
Mar 14, 2009 | Reebok Exercise & Fitness
Repair Manual
you will remove the body screws ... slightly loosen the camera body until you can remove the battery cover out ...... replace with a new one ... fit the body back in place and put the screws back.........
Oct 19, 2008 | Nikon Coolpix L1 Digital Camera
Cycling Logo
85 people viewed this question
Top Cateye Fitness Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cateye Fitness Cycling Expert? Answer questions, earn points and help others
