Question about Harman Kardon Audio Players & Recorders
Harman Kardon AVR 1700 only flashing power but will not stay on
I have a Harman Kardon AVR 1700 will not power up. Press power, it comes on 1 sec and then there's only a flashing amber light. No display or anything. The reset with the Surr Mode button has no effect. Can you offer any guidence.
    New Friend:
  • 87 Answers
You have electronics problem.
a damaged component.
Posted on Apr 18, 2014
SOURCE: My Harman Kardon receiver (
I used the live chat and the problem was resolved.
Usually the problem are strands of speaker wires which cause shorting and protection shuts off the receiver in order to prevent damage. There was one speaker that I repositioned recently which was causing shorting. I twisted the wires and tightened them in place and my receiver has been working w/o a glitch. I was lucky that I did not have to check all the wire strands on the receiver and all the speakers.
Problem solved and I learned valuable lesson.
Posted on Dec 28, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
  • 308 Answers
SOURCE: AVR amber light will not return to blue after
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Posted on Mar 04, 2010
SOURCE: I have a harman kardon avr 745....looks frozen
Did you happen to come up with a solution. I have the same problem, 100% as you have described it.
Posted on Apr 23, 2010
jonsen
  • 62 Answers
SOURCE: harman kardon avr 100 no power
check the fuses it help the power !
Posted on Jun 10, 2010
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
Why does update say the usb folder is empty?
formatting wipes everything off the device usually, you may have deleted what was on there, hope this helps.
Jun 23, 2014 | Harmon Kardon Harman Kardon - Avr 1700...
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
Avr-1700 airplay
I have the same problem. Please let me know if you were able to find a solution. Carzev@yahoo.com
Dec 21, 2012 | Harmon Kardon Harman Kardon - Avr 1700...
How do i reset an harman kardon avr-310
There is no reset for it, If it doesn,t stay on something is wrong with it,End it has to be taken in for repair,
Nov 01, 2012 | Harman Kardon Audio Players & Recorders
Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Dec 05, 2007 | Harman Kardon AVR 120 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
806 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
