Question about Cub Cadet Garden
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
I start it up pull out on the pto knob and it wont engage the blades is the switch bad
    Scholar:
  • 126 Answers
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Posted on Apr 16, 2014
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 10865 Answers
SOURCE: cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
Posted on May 28, 2010
  • 146 Answers
SOURCE: Mower deck PTO switch will engage when pulled but stop when rele
The PTO switch has failed. There is an internal spring and plastic parts in toggle switches that keep them in the actuated position. It's not practical to take the switch apart to fix it, but replacement switches are readily available - probably $12 - $20. It's a good idea to disconnect the negative terminal from the battery before you do any electrical work. Be sure to put the wires on the corresponding terminals of the new switch. Good luck! Please rate if you find this helpful, thanks.
Posted on Jun 04, 2010
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
  • 146 Answers
SOURCE: Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Posted on Jul 10, 2010
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Zero force 50 Cub Cadet runs fine , but when the mower deck switch is pulled , blades do not turn, does not engage
This would be one of a few different things, first check to make sure the belt is on properly and hasnt came off any pulleys, next check the clutch relay and fuse, next check the pto switch, and if all those check out, check the clutch for engagement, if it tries to engage with pto switch, then it may just need adjusted, if it doesn't try to engage, the clutch will need replaced, but check the other possible causes first.
Oct 14, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1040 blades spinning when pto isnt engaged
Sounds like you forget a spring or the routing belts are
wrong.
Sep 29, 2012 | Cub Cadet Garden
PTO WONT WORK on myCub cadet ride on mower LT 1045
i seems you already found the cause its a electrical problem look at all the wires you have a loose connection some ware the wires also like to break where they go into the clutch
Jun 28, 2012 | Cub Cadet Garden
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Cub cadet lt 1018 blade will not engage when i pull knob up
It sounds like the PTO is not engaging. This is the pulley on the bottom of the crankshaft and the belt for the deck goes around. It may be time to buy a new electric PTO to solve this problem.
Go to www.precisionope.com. and put your information in. you should find a part number you need there.
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
291 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
