Question about Whirlpool WMH31017AB 1.7 cu. ft. Microwave Hood Combination in Black
WMH31017AB does not turn on
The light or the fan also does not work.
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
If it's totally dead, check the main fuse - located inside the cabinet where the power cord enters. If this is the problem, check to make sure the door switches are working properly, and the tension on the fuse holder is sufficient to prevent the fuse from heating up during operation. The fuse holder might have to be replaced. Make sure the unit is unplugged before testing anything, and either discharge the high voltage capacitor, or stay well away from it. 4000 v going through your finger lights it up pretty well, and is very unpleasant!
Posted on Apr 17, 2014
Testimonial: "Dave, Thanks for the info. I will check what you suggested and see if it works."
How do I take the door apart for cleaning?
you don't, it is not for you to do. if you take it apart you may damage it and the microwave can escape. Do not disassemble the door.
Jan 04, 2016 | Whirlpool Microwave Ovens
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
Samsung microwave oven Model # SMH9151S. Turntable not turning fan inside (not the exhaust fan) is not working either.
It may be a failed relay on the control board, which I repair affordably.
See my profile picture if you need more help.
Jun 22, 2015 | Samsung Microwave Ovens
Whirlpool - troubleshooting
That is the power level or brightness of the light setting.
Aug 08, 2014 | Whirlpool WMH31017AB 1.7 cu. ft. Microwave...
How to use Whirlpool WMH31017AB microwave
Visit this link for manuals, replacing the XXX with the full model number found on the tag on your microwave (not on the service manual).
XXX&siteCd=WHRCOM&userType=Consumer">http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
Feb 16, 2014 | Microwave Ovens
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave VM240 AV underchassis fan & light don't work
It is more than likely there are one or two defective door switches that need to be replaced.
May 07, 2012 | Microwave Ovens
Model is GE JVM1430BD002. Microwave works but range fan and lights do not. Unit "popped" when fan was turned on one time and hasn't worked since. Is there a fuse or breaker for the range hood functions?
Yes - there is an internal "special" in-line fuse. Most likely it is the fan that has caused it. Clean the fan with switch-cleaner spray and make sure it is smooth running. Replace special fuse with identical version.
Check lights before operation.
Replace all covers before test.
Oct 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Jan 09, 2008 | Microwave Ovens
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool WMH31017AB 1.7 cu. ft. Microwave Hood Combination in Black Logo
52 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
