Question about Maytag Washing Machines
Pressure switch? Have maytag performa PAV2300AWW washer. replaced the H2O pump and didn't solve problem of water draining out. No hoses clogged, not even a little. Have been able to solve problem for last 4 months by hitting the switch for load level (reset?). Last night the washer didn't drain,. and this hasn't fixed problem. Nothing blocked and H2O pump seems to be working properly. Is this a load level switch problem or a water intake switch problem and easiest solution?
    Habit-Forming:
    New Friend:
  • 21 Answers
Sounds like you are having a syphoning issue. caused by having the drain hose too far down the home standpipe. very common problem. test..fill the machine, high water level. when it stops filling turn off. advance into spin/drain for just a moment and shut off. listen to hear water still going down the drain.
repair.. raise the drain hose nearer the top of the stand pipe. also do not tape/seal the hose into standpipe. it has to breath. good luck. kihm washing machine drain hose installation Google Search
Posted on Jun 13, 2017
the dr
  • 447 Answers
SOURCE: Maytag Performa washer won't drain
there may be a object in one of the hoses going to and from the pump. be sure have you taken the front panel off yet??? If not it has two clips on the bottom on the two sides than the panels swings towards you to unhinge from top. The pump has a clear body and you can visually see an obstruction. Sometimes i find that a metal object coin, etc can actually chew the fins off the impeller. That would be the only reason for it not to pump anymore. Also release the tension on the belt. Maytag wants some slack for the motor to slide on the motor plate proper.
Posted on Oct 05, 2007
SOURCE: washer won't spin
Where is the outlet filter?
Posted on Dec 18, 2007
  • 3 Answers
SOURCE: frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Posted on Jul 28, 2008
  • 298 Answers
SOURCE: water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Posted on Mar 26, 2009
  • 50 Answers
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Posted on Jan 08, 2010
Our Maytag PAV2300AWW Performa top load washer fills with water fine, draisn fine, spins fine, but after filling with water (even on "Mini" size load) it begins to agitate and then quits completely and...
If it was the bearing it should be leaking water out the bottom! It is more than likely the water pump. The seal in the pump drops down and then makes noise. The pump should be in rear. tilt machine back remove belt then try turning the pump by hand if tight replace.
List price is about $89.99 you can find it on Ebay cheaper
Jul 05, 2014 | Maytag PAV2300 Top Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Replace drain hose
if u add an extension to the drain hose it will take a long time to and go down the pvc pipe. Just check for clog. by giving it for service one time may work.
Nov 03, 2013 | Maytag Performa PAV2200
It wont work it flashes fl
the Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Aug 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
I have a maytag washing machine model PAV2300AWW that is leaking water and only draining 1/2 of the rinse load. Could this be a pump motor issue?
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 16, 2010 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
