Question about Crafts & Hobbies
How to hook up lionel #41 to gateman and power supply
    New Friend:
  • 62 Answers
Here is the manual for the switcher. http://www.lionel.com/media/servicedocuments/71-8474-250.pdf
Here is a link for gatemen, select the one you have to find the manual.
http://www.lionel.com/Products/Finder/SearchResults.cfm?doAction=search&Keywords=gateman&CategoryID=39&Gauge=&RailLineID=&CatalogID=&CollectionID=&searchWithin=Current
Here is the link for power supplies.
http://www.lionel.com/Products/Finder/SearchResults.cfm?doAction=Browse&CategoryID=40.
Posted on Apr 16, 2014
Want to use this on 220v aussie supply to power 1947 221 lionel train loco Suitable?
ohh no that id not try at all , one can first use a power converter that one can buy off many online sources to convert 220 volt down to 110 volt then to transformer this will be safe 4 unit, the 50HZ to 60 Hz doesn't matter to much as well unless one plans on using the lionel sound generator , then its not gonna sound to spry as it will be a bit slower !!
Jun 16, 2015 | Lionel O Train Transformer 6-14198
How to replace arm on Lionel 1054 gateman
If it is the 1045 flagman, you need a replacement arm with the attached flag. disconnect the man from the metal base and open the figure with the screws on his back. Disconnect old arm or whats left of it and reverse the process to re assemble. If you do not have a 1045C contactor, one side of a 154C will work
If it is the 145 gateman the arm has a screw or drive pun into the man's shoulder. If you can get a seperate arm this is the way to go. if not parts dealers will have the complete man. Open the base undo the screw that holds the man to the arm remove damaged man, Reverse process to reassemble
May 11, 2014 | Crafts & Hobbies
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Where can I find a replacement motor for Lionel 6-24137 Mr. Spiff and Puddles accessory
Here is a link to contact Lionel Parts & Services:http://www.lionel.com/ContactUs/
They'll be able to supply you with a motor.
Jan 06, 2013 | Lionel 6-24137 Mr. Spiff and Puddles...
Need diagram for hooking up #252 Lionel Crossing Gate
Here's a link to the Service Manual to the 252 Crossing gate.
http://www.lionel.com/media/servicedocuments/71-2714-250.pdf
Dec 31, 2012 | Lionel O 27 252 Auto Crossing Gate
How to wire a Lionel block signa lwith insulated track.
Only one outside rail has to be insulated from other sections. A hot wire goes to the signal block. The other wire from the signal block goes to the section of track with the insulated outside rail. When the train passes over the section of track with the isolated rail, a connection is made to the power supply common through the wheel axel. The other wire from the aux supply (common) is connected to the same common as the supply powering the rails. Power the block signal from an aux supply not rail power.
Aug 30, 2011 | Lionel Mpc 6-2163 Auto Block Signal C9
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Crafts & Hobbies Logo
129 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
